It is currently Sun Oct 26, 2025 6:57 pm
PostPosted: Fri Feb 24, 2012 7:05 pm
Here's my predicament:
90 Dodge Colt w/ 4g swap
Expo front knuckles
I'm assuming stock 1.5 axles
It looks like the expo and dsm would use the same seal. Problem is my axles aren't as big on the end as DSM axles.. so the seals I bought are a 1/4" too big or so.
Stock colt inner seals are way too tiny to pop into the expo hub.
Anybody have any ideas? Trying to avoid having to buy DSM axles at the current moment.. and I'm not even 100% sure I could use them anyways.
1990 Colt AWD 8.8
PostPosted: Fri Feb 24, 2012 11:56 pm
I know exactly which seal you need.
http://www.4g61t.org/forum/viewtopic.ph ... ake+thread
PostPosted: Sat Feb 25, 2012 11:29 am
I've seen you thread before.. just couldn't find it last night!
Thanks.. will try that and report back.
1990 Colt AWD 8.8
PostPosted: Fri Mar 02, 2012 7:53 am
Ended up with a Timken cross referenced part that matched that #.. fit perfectly!
Thanks again
1990 Colt AWD 8.8
