It is currently Mon Oct 20, 2025 8:27 am
Post new topic  Reply to topic  [ 109 posts ]  Go to page Previous 1 2 3 4 58 Next
PostPosted: Tue Dec 27, 2011 4:37 am
Still ticked ith the head I purchased fron RedSleeper..
didnt even know i sold you a head.. hahah Do you remember which one it was?
PostPosted: Tue Dec 27, 2011 7:18 am
I plan on using an 8.8 out of a fox body so I can use my 4lug wheels. Have to change the gears to 3.31 to match the front and convert to disk brakes. Hopefully I will be able to bring my turbo mirage brakes over and build a caliper bracket. I have a few 8.8s local to me on craigslist for $150-$250.
The head is the ported 1g head with all brian crower valvetrain and brian crower 280s. The head has obx cam gears and you wrote "Garbage" on the exhaust cam :).
PostPosted: Tue Dec 27, 2011 7:31 am
Here's is the 4link kit.
http://www.jegs.com/i/Competition+Engin ... 7/10002/-1
PostPosted: Tue Dec 27, 2011 9:40 am
PostPosted: Tue Dec 27, 2011 10:07 am
Hahaha the head off my gsx. My buddy built the head when he owned the car
He hates BC cams. So he wrote garbage on them. There was nothing wrong with them at all. They were bnib when he bought them.. I was wondering where that head went
PostPosted: Fri Dec 30, 2011 5:36 pm
Today was a good day.
PostPosted: Sun Jan 01, 2012 9:07 pm
did you know that the pistons were on wrong. the bigger valve reliefs are on the intake side. what piston to cylinder wall clearance are you running? I find that anything tighter than .005" will cause major scuffing and rob power majorly. I runs .007" of clearance on my engine.
615hp and 475tq at 23psi and 75shots
http://gadsm.org/showthread.php?t=37685
PostPosted: Mon Jan 02, 2012 8:07 am
That makes sense with the pistons. I paid to have the motor assembled at a machine shop, next motor I plan on assembling. I don't know what clearance they used. I will do my research before on piston to wall and ring gaps before the new pistons go in.
PostPosted: Sun Jan 15, 2012 9:59 pm
Plans changed. Sold the rods to help a friend get his motor back together. Also found out the mustang 4lug is different than our 4lug, 4x4.25 vs 4x4.5. So I ordered a set of ranger driver side axles for the 5lug conversion. Still have to figure the brake setup. I guess I can simply grab rotors, calipers and caliper brackets off a ranger at the junkyard. PM me if you are interested in purchasing the volks. Hopefully I can get some welding accomplished tomorrow.
Mock up before hacking the floor...
Had to cut the floor.
PostPosted: Mon Jan 16, 2012 9:47 pm
Factory brackets removed, 4link bracket tacked. I borrowed a tig and am teaching myself to use it as I go.
PostPosted: Tue Jan 17, 2012 9:04 am
Was looking through Craig/Gsx build and noticed a photo on this page in which he changed two studs to keep the 4 lug. http://www.4g61t.org/forum/viewtopic.ph ... 1&start=90
I'm going to look into that today, I would love to keep my wheels.
PostPosted: Wed Jan 18, 2012 12:06 am
It looks like I going to have to drill the axles to keep 4lug, anyone know how it was done on the cataplt?
Here is the axle with the 4link brackets in their final location.
PostPosted: Thu Jan 19, 2012 11:22 am
This is where the rear end will be. Finishing the front chassis brackets tonight, fingers crossed.
PostPosted: Thu Jan 19, 2012 11:34 am
Criag bought aftermarket axles for a 4lug fox body I believe. Or he had them drilled to 4x114 when he.bought the axles
He also used the 8.8 out of a turbocoupe.
PostPosted: Thu Jan 19, 2012 9:58 pm
