It is currently Thu Jun 06, 2024 4:56 am
Post new topic  Reply to topic  [ 116 posts ]  Go to page Previous 1 2 3 4 58 Next
 Post subject: Re: AWD v2.0
PostPosted: Wed Dec 14, 2011 4:27 am
Killing me shaun.. atleast give me a day to get some pictures together.
PostPosted: Sat Dec 17, 2011 9:04 am
Quick update...
I got the rear all mocked up/welded and pulled back apart. Pulled the rear subframe apart to get painted. I bought the stuff to make custom rear upper and lower control arms, and also to make a custom active toe eliminator kit. No way Im paying $225 for some hiems joints and a chunk of steel.
I also couldnt find a set of 5lug wheels that i wanted, so i managed to track down the guy who bought my Gram light 57c off of me 4 years ago. luckily he still had them, and i bought them back. also got a complete set of 4 galant hubs off TheDSMGuy.
Thats it for the car, it hasnt been touched the last week or so because of this.......
A buddy had a 92 AWD talon... He got hard up for money, and make me a deal i couldnt refuse.. Im trying to sell all the stuff im not useing to recoupe some of the money. But it pretty much had everything to finish the colt, besides injectors, and a QM twin disk. here is a quick list of what im keeping..
Buschur stage 3 short block
Buschur Race FMIC kit
built head with HKS 272
JHracing divided t4 mani.
GT4202 with t4 housing
2 tial 44s
brand new oem mitsu calipers all the way around. 2pot up front.
new drilled/slotted rotors
the car was built 4-5 years ago and had a 16 and 450s for break in.. he pulled it apart for the 4202 setup and never finished it. he got married and it got pushed to the back. he says it probably has less then -500 miles.
I'll get picturs in the next couple days..
PostPosted: Sun Dec 18, 2011 9:28 am
Sweet the gram lights are hot.
PostPosted: Mon Dec 19, 2011 12:19 pm
Alright.. got a few hours in the garage today..
I had already made the one side. so my measurements were already done so i went ahead and welded some shit up
Then i took the control arm and cut the thin lip off, to get to the thicker material
But apparently im an idiot and didnt get a pictuer of it cut off.. Whoops..
slid the already welded up sleeves/hiems in and welded it up
Also drilled a few holes, and plug welded everything for extra strength
so now my subframe/control arms are done, and about ready to go out to get blasted and painted.
Also, With my rear shock towers lowered/leveled. my ksports were almost all the way maxed out, so i didnt have anymore lift and i only had a 1/2'' wheel/fender gap. that leaves me with no room for adjustments. I wasnt a Huge fan of the way it was done on anti-lag/adams AWD car. so I decided to make some "strut spacers" I made them 3" and plan on cutting them down to 1.5/2" if needed. There made out of 1/8" plate and 3/4" .125 wall tubing
Thats about all i have right now.. Once this parts car is gone, I'll have more time to work on my pile. It should be on the ground rolling in a couple weeks!
PostPosted: Mon Dec 19, 2011 1:08 pm
You interested in making anymore of those strut spacers?
PostPosted: Mon Dec 19, 2011 1:11 pm
Holy wow John. I would cut the strut mounts back off and lower them more before running those heavy ass spacers. Eff that noise!
PostPosted: Mon Dec 19, 2011 1:58 pm
Id rather make them a little heavier. Then light/ thin and have them collapse under a hard launch.
I could make another set I suppose
PostPosted: Mon Dec 19, 2011 2:02 pm
There's no way to lower it more without rebuilding the wheelwell/strut tower
PostPosted: Mon Dec 19, 2011 2:45 pm
Looked at your pic of the strut towers again, I can see what you are saying about not being able to go any lower.
PostPosted: Mon Dec 19, 2011 4:51 pm
I didn't notice from the pics but are they angled to suit the offset mounting point from the dsm sub frame?
PostPosted: Mon Dec 19, 2011 5:26 pm
Nope. I cut the shock towers and reangled them.
PostPosted: Tue Dec 20, 2011 7:43 am
So what a minute, you lowered the factory strut towers, and then you had to lower them some more ?
I am confused
Warren
PostPosted: Tue Dec 20, 2011 7:50 am
I probably won't need those spacers. With 225/50/16 I had 1/2" wheel gap on Jack stands. Under full weight, I'm afraid ill have no more up adjustment and tucking tires. I got my ksports as high as they will.go. Its getting 215/45/16s tho. Ill know in a few weeks once its on the ground.
Pos
PostPosted: Tue Dec 20, 2011 8:17 am
Keep me posted, because I am in the process of redoing those trailing arms myself.
with my car on jackstands, I have over a FOOT of travel lol and from the pictures I showed you before, the car is sitting way to high even with ground controls lowered all the way
Warren
PostPosted: Tue Dec 20, 2011 9:03 am
What struts are you using? Csm?
