It is currently Mon Oct 20, 2025 1:49 am
 Post subject: re: servo brake fluid
PostPosted: Thu Nov 10, 2011 7:26 am
Hi all, I am encountering some brake fluid from the master cylinder coming out after a run.
My friends told me that as the engine now is turbo and no more aspirated, I have to check well the non return valve.
Wher is this valve situated? in the pipe connecting the brake servo to the throttle body or is internally in the servo?
regards
PostPosted: Thu Nov 10, 2011 9:17 am
It SHOULD be in the hose that connects the booster the intake manifold. I have used valves from Hondas to replace broken OE valves.
PostPosted: Thu Nov 10, 2011 1:05 pm
I baught one and put it between the pipe, seems that the problem of brake fluid leacks is sloved....
thanks
