It is currently Thu Oct 23, 2025 4:17 am
Post new topic  Reply to topic  [ 42 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Oct 23, 2011 8:16 am
I see. Any kind of swap into a chassis this different from the donor car would require cutting and welding. But you know this.
If you are gonna swap it put a fuel injected 318 into it. Then add a turbo. HAHA
PostPosted: Tue Oct 25, 2011 8:54 pm
I was asking about how he thought you could AWD swap one of these chassis... maybe he didn't realize it wasn't transverse engine :)
The ones I've seen in progress are not a TT swap, but I agree, its go to be an overkill for the car. Just neat to see something different.
i would do what they are doing with some muscle cars of cours there is no guarantee you wouldn't have to cut and dice. but the conversions being done like a 68 charger on a 2010 chrysler 300. drop the body over an awd chassis. west coast customs did it to a charger for the guy from csi. and also a 70 gto over a 2008 gto. i've thought about my 77 colt on top of a newer awd colt or evo.
PostPosted: Tue Oct 25, 2011 8:56 pm
That is cool and all but ranks on the level of a Fiero with a "Ferrari" body kit in my opinion. If you have a '78 Plymouth Arrow then rock the Arrow and shoe-horn a nasty build into it.
PostPosted: Tue Oct 25, 2011 9:32 pm
how about this in the arrow?
http://www.bangshift.com/blog/eBay-Find ... -Colt.html
PostPosted: Wed Oct 26, 2011 7:00 am
Sure it will fit. It's been done, but I just don't understand the fascination with that swap. Every time I drive my 72 Colt to a show someone tries to get me to do that.
I'd stick to something simple on the arrow, a Mitsubishi variant of some sort, probably be a blast to drive with just a little bump in displacement and slight tweaks.
Btw sorry to to OP for whoring his thread! :)
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Mon Oct 31, 2011 4:57 pm
My thread has grown! I havent done anything but gathered parts for this car. Im currently looking for an LSD rear end. Research tells me that I can swap in a Starquest Pumpkin into my housing. Ive also been looking into using a totally different rear, like from a 98 explorer. So for now the parts keep piling up while I finish my other projects.
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Mon Oct 31, 2011 10:20 pm
Look for a Ford Turbo Coupe rear end. IRS, LSD and uses the same differential, ring and pinion as the solid-axle Ford 8.8".
PostPosted: Mon Oct 31, 2011 10:55 pm
CSM O.G.
thats awesome. The auto isn't junk, its a smaller version of the torqueflite iirc. check out http://www.projectzerog.org for lots of like-minded rwd Mitsu folk
edit: here you go...
http://en.wikipedia.org/wiki/TorqueFlite#A904
PostPosted: Sat Nov 05, 2011 1:55 am
which is what I have sitting here..been trying to sell it to him cause im going a diff route when I do the auto swap.
PostPosted: Sat Nov 05, 2011 5:24 am
Ive seen it, its all there even with brakes on it, but your gonna have to go help him finish his other 5 projects first
89 turbo chili
92 gvr4 96/1000- sold to mois used car lot
PostPosted: Wed Nov 09, 2011 3:38 am
I dont like the Lug pattern the Turbocoupe has!
Also, I have also heard very good things about my auto tranny 8) I am a member on ProjectzeroG and hotrodcoffeeshop.
88 Cummins Suburban
PostPosted: Wed Nov 09, 2011 10:13 am
So change it. Cutting and welding saves the day every time. HAHA
