It is currently Wed Oct 29, 2025 8:33 am
 Post subject: In a bind, need help!
PostPosted: Sat Sep 03, 2011 10:02 pm
I'm in a serious bind. I need an EPROM for a stock 1989 Plymouth Colt GT Turbo. Mine has two pins broken off of it. I don't need a whole ecu, just the EPROM.
Anyone point me in the right direction???
PostPosted: Sat Sep 03, 2011 10:44 pm
try soldering a lead from another component like a capacitor or resistor. I have done it before(never with an ecu, but the process should go like this:
1. put eeprom on in correct direction.
2. cut a lead off a "traditional" led,diode, capacitor or resistor.
3. put lead in missing spot, and cut to size.
4. solder to chip.
This is a temporary fix, because if you remove the chip again, obviously its going to break. but as long as you don't move it, it should work a treat.
4g61t.com
PostPosted: Sat Sep 03, 2011 11:37 pm
Ty. Trying it now.
Edit: Zanzibar!!!! Fired right up. Thanks Evotistical.
PostPosted: Mon Sep 05, 2011 5:24 am
No Problem! :butthead: Please add your location to your profile!
4g61t.com
