not sure about the 97-01 blocks, but the 93-96 block swap over not sure about the head since mine was a 12v, i have a 94 4g15 in my 91 which was in my 92 before hand. you do got to chase the threaded holes on the block for the motor mounts as the mounts are on the transmission and not the block, but the hole are there and already tapped just got the clean out the road crud thats in there. the exhaust will swap over just need the down pipe too. the intake i didn't use cause of many reasons, so i reused the intake that came stock with my 92. hope that helps some.
_________________ 91 plym colt 4g 4g15 12v/ 4g37 upgrades 5spd flat black
