It is currently Wed Oct 22, 2025 1:02 am
 Post subject: safc and 4g15
PostPosted: Sat Mar 06, 2010 1:31 pm
since its not a powerhouse , has anyone used safc to tune for MPG? a side benefit would be more power....
1992 Dodge Colt GL 1.5 auto
 Post subject: Re: safc and 4g15
PostPosted: Sat Mar 06, 2010 10:22 pm
Doubt it, at least us US guys. I think one of the jamaican guys did use one once. I don't see the point though, to lean it out for gas mileage all you'd have to do is take the maf out and look for the two tubes under the sensor, they should both be blocked off, just drill a hole in one of the blocked off sections.
PostPosted: Sun Mar 07, 2010 8:24 pm
olny one was blocked i drilled a 5/16 hole in it. will that work? doesnt seem like much....... changed plugs and wires cap was ok wires had blue corrosionat the cap....... purrs more now
PostPosted: Sun Mar 07, 2010 9:29 pm
That'll work. You won't see a recognizable difference though.
PostPosted: Sun Mar 07, 2010 9:36 pm
hmmmm well im only out like 10mins for possibly no gain right?
well id still ......even if out of curiosity....... like to play with a SAFC or similar
PostPosted: Fri Apr 22, 2011 12:45 am
I may be on that same path there with putting in an SAFC. However, the WBO2 gauge itself will be a bit to consider swapping in considering it costs quite a bit. The WBO2 sensor itself is relatively cheap ($60 or so) and it would be nice to see when the engine's running a bit too rich or too lean. If I end up getting it all hooked up, I'll give some posts. Let alone, doing the mod to the stock MAF. Speaking of which, is doing the MAF hack to the stock MAF or to the 4G37 MAF?
1990 Eagle Talon TSi AWD
1986 Jeep Comanche Custom
PostPosted: Fri Apr 22, 2011 1:06 am
BANNED FOR FRAUD
Is your goal just to try and beat our shitty SoCal gas prices? Just filled up for $4.21 a gallon.
Jason Veraldi
Scammer
PostPosted: Fri Apr 22, 2011 10:23 am
$4.15 for 93 octane here in Ohio..
Look at some other places in the world, makes you not want to complain.
PostPosted: Fri Apr 22, 2011 10:30 am
Pretty much yeah. $3.87 for 87 where I'm at. Getting every MPG out of it that I can.
PostPosted: Fri Apr 22, 2011 11:44 am
ditto i have motorcycles too and i run 91 in all of them 15.00 to fill up!!!!!!!!!!! ffing crazy thank god i still get 42 mpg on them
Id still like to see what safc could do for a 4g15 both power and economy
PostPosted: Fri Apr 22, 2011 2:11 pm
How big is the tank on the Colt anyway? 'Bout 10 gallons or so? Ah, and one more thing that I've to do; make sure that the tank is siphoned out. F. Hate doing that. What's the Colt get on average for gas mileage for a higher-mileage engine? I'd think at least 29 mixed driving.
PostPosted: Fri Apr 22, 2011 5:01 pm
28-29 mixed ive gotten 32.3 on the road best with air on and 75 mph
