It is currently Wed Oct 22, 2025 5:43 pm
Post new topic  Reply to topic  [ 123 posts ]  Go to page Previous 13 4 5 6 79 Next
 Post subject: Re: '89 Summit LX
PostPosted: Wed Mar 30, 2011 12:23 pm
Looking good man, I like to see new things tried on these cars. How do you plan to mount the bracket to the spindle with one of the mounting ears cut? Dill a smaller hole beside of the cut one?
PostPosted: Wed Mar 30, 2011 12:27 pm
looks good man
Thanks Chris man! Wanna help me tune it later? Text me.
Yup. I am going to drill closer toward the bearing and run a bolt through from the backside. I wish cast iron could be welded to processed steel; I would go that route and not deal with four bolts and nuts per caliper...
PostPosted: Wed Mar 30, 2011 2:55 pm
Maybe drill/tap for a stud? Would make for a cleaner install I guess. Not that you would ever have to remove the brackets again once they are on. How big are those rx7 rotors anyway?
Do you have a dsm rear end yet? I actually have a GVR4 rear subframe and would like to do a 5 lug swap so I have the rear 4 lug hubs if you need them.
PostPosted: Wed Mar 30, 2011 6:47 pm
Drilling and tapping for a stud is a great idea. That will be my new course of action.
The rotors are actually 2g rotors. I am building this brake swap to fit inside 15" ROTA rims. I could just put the dual piston GVR4 brakes on but the weight difference is significant. One GVR4 caliper weighs noticeably more than both of these calipers.
I currently have two complete rear drivetrains just sitting at my garage. One is a 3 bolt LSD and the other is a 4 bolt LSD. And I have a set of GVR4 rear hubs in a box... Sorry Chris man at the moment I am stocked up on parts. LOL
PostPosted: Wed Mar 30, 2011 9:26 pm
I completely understand, and yes the twin piston calipers are heavy. Those are 4 piston usits though, correct? You don't happen to have a set of 5 lug rear hubs in your parts stash do you?
PostPosted: Wed Mar 30, 2011 9:52 pm
lol it cool man just remember all the work I've helped you with. lol
PostPosted: Thu Mar 31, 2011 7:32 am
Yes they are 4 piston calipers. The pads are taller than the dual piston pads but skinnier by an inch. Surface area will be similar. I do not expect this brake set-up to work any better than using GVR4 parts but it will take weight off the front of the car.
I'll be over later today. Gonna lower my AFRs and try to get some more timing out of this engine.
PostPosted: Thu Mar 31, 2011 10:05 am
sounds good man ill see ya later
PostPosted: Sat Apr 02, 2011 2:23 pm
Woo hoo! Finally got to run at the track last night. Went down with trooper. I am very happy with the results.
I was launching at 3500 rpm off the stutter box. Tires would spin going into second and third. 2.3 60' is good for a FWD car with street tires. Gained 18mph in the second 8th and trapped 94mph. This is on 93 octane gasoline and my Sleeper 16g pushing only 9 psi of boost on a stock NA 4g61. AFRs were right around 11:1 and timing was set at 22 degrees at the top end. I found that the car was leaking coolant out of a heater hose, not burning it. So the boost controller is going on and I am going to push it up to 12 or 15 psi. As long as the clutch doesn't give I will push it a little harder.
PostPosted: Sat Apr 02, 2011 2:50 pm
good shit! bring it up to norwalk next time
1989 Dodge Colt E [4g63T]
2005 Saab 92X awd-turbo :)
2003 WW EVO8 FlexFuel
PostPosted: Sat Apr 02, 2011 3:28 pm
So far.... 4 hours man. What day does Norwalk do test and tune?
PostPosted: Sat Apr 02, 2011 7:49 pm
Friday iirc
PostPosted: Sun Apr 03, 2011 12:58 pm
fruit and banana norwalk. D42 all day for test n tune.
PostPosted: Sun Apr 03, 2011 2:14 pm
+1 this. But norwalk is a nice track.
PostPosted: Mon Apr 04, 2011 9:28 am
Put oil squirters in the NA 4g61 block yesterday. Was simple and straight forward. I feel much better about turning up the boost now.
http://www.4g61t.org/forum/viewtopic.php?f=6&t=34502
