It is currently Tue Oct 28, 2025 4:47 am
 Post subject: TPS connector
PostPosted: Sun Jan 30, 2011 1:26 pm
I need a TPS connector with as much wire as possible.
Thanks,
George
 Post subject: Re: WTB
PostPosted: Tue Feb 08, 2011 2:11 pm
Thanks,
George
Is this the correct throttle body for an 1990 GL 8 valve?
I went to rockauto and they list two different TPS's for this year. The previous owner has got the wiring ghetto rigged and you can see why I need a connector!
PostPosted: Tue Feb 08, 2011 4:04 pm
That is a 91/92 throttle body.
PostPosted: Tue Feb 08, 2011 9:34 pm
So once I get the connector problem corrected I can go with the 4G37 upgrade on the 8 valve?
 Post subject: Re: TPS connector
PostPosted: Tue Feb 08, 2011 11:20 pm
You should be able to. Does it look like they messed with the wiring for the idle motor? From what I can tell that part looks stock. You can actually grab that connector from most 1g dsm's, 1.8 or 2.0. Also quite a few Hyundai's from the early to mid 90's use it as well. The colors may not be the same but you could wire it up using the location of the wires. Either that or text/call me tomorrow and remind me to look for my old 12v harness.
PostPosted: Tue Feb 08, 2011 11:50 pm
Chris,
You should remove your telephone number before the bots get it... or you will be getting spam texts!
Thanks,
George
PostPosted: Wed Feb 09, 2011 12:00 am
Done :P
