It is currently Tue Oct 21, 2025 7:08 pm
PostPosted: Thu Sep 10, 2009 10:18 pm
hmm im not sure what trans is in my DD its a 1.5l 92 colt, it has a 5 speed cable trans.
PostPosted: Fri Sep 11, 2009 3:06 pm
the 4spd i took out was a f4m21 and the 5spd i put in was a f5m21. to tell was yours is, on top of the bellhousing there is a spot with stamped numbers and letters with the trans still in the car it should be located somewhere under the dizzty on the trans.
91 plym colt 4g 4g15 12v/ 4g37 upgrades 5spd flat black
PostPosted: Tue Nov 03, 2009 7:22 am
I'm planning also to upgrade my 4G15 4spd to 5spd but planning to buy only the 5 spd transmission and would like to use my 4spd trans cable.. the question is..it is posible to use my 4 spd csble to my 5 spd transmission? any issue?
My Feedback?
Asked
Bowdown
MattGSR
Coltsfan
Moulin13
Wrx110487
PostPosted: Wed Nov 04, 2009 9:55 pm
all your 4spd stuff will work with the 5spd, i just have to shim the shift cable bracket out a 1/2 inch.
PostPosted: Fri Jun 25, 2010 6:58 pm
Well, last Friday brought me enough ambition to tear apart the DD after work in hopes of being possibly the first 4G trans swap driving on the road.
BUMP for a 1-year anniversary w/ no known issues! :P
-Shawn
MEMBER #1495
'92 Dodge Colt 63 swap (SOLD)
'92 Galant VR-4 (it's Alive!!)
'12 Forester (DD)
GONE:
'92 Plymouth Colt 12v 4M->5M
'90 Dodge Colt GL 8v 3A
'89 Plymouth Colt 8v 5M
'92 Galant LS
'92 Galant GSR
'93 Galant LS
'93 Galant S
PostPosted: Fri Jun 25, 2010 8:26 pm
Haha, congrats man!
PostPosted: Wed Jul 07, 2010 7:21 pm
I finished mine today. Maroonmetalic (Shawn) hooked me up this weekend with the tranny. Second gear is kinda iffy so I will play with the spacing on the cable bracket this weekend. Thanks Shawn!
I had the 4 speed tranny that was popping out of gear. Nice to know there is another option.
R.P.M's are slightly higher in 5th gear than the 4 speed.
edit: I had to space my bracket out to 5/8 of an inch to get reliable 2nd and reverse gears.
PostPosted: Sun Jul 18, 2010 9:11 pm
i had to play with mine also but ever since it has worked like a charm :supz:
PostPosted: Mon Oct 18, 2010 10:27 am
UPDATE!!!
Well, sadly my 5-speed trans went out this last friday. I was hoping it was just an axle seal, but after installing new ones I reassessed the fluid leak & decided it was in my best interest to make sure the case wasnt cracked.
Found out I blew something up in the differential but was able to drive 15 miles home on the trans
(plus probably a mile of highway/city driving before I noticed the leak!).
Looks like the transmission is going back to the junkyard it came from.
(Keep in mind this trans was in a previous car before it was installed in the one I took it from. Mileage unknown.)
-Shawn
PostPosted: Mon Jun 13, 2011 1:32 pm
Wow, hard to believe it's been that long since I put the 5-speed cable trans in my Colt. Didn't realize I was the first person to ever do it either... Weird.
Anyways, I used the bracket that was on the 5-speed transmission. I never had trouble going into any gear. I still drive this car everyday with the 5-speed. The only issues I've had have been with the passenger axle popping out. But that has more to do with my suspension upgrades that anything to do with the transmission.
Here's my project thread with more info and pictures for doing this swap. http://www.4g61t.org/forum/viewtopic.php?f=9&t=29480
PostPosted: Tue Jul 08, 2014 5:10 am
This should be archived, I did the f5m21 from a 4g swap and had all the same issues
94 Mitsubishi Mirage "4dr"
