It is currently Tue Oct 21, 2025 10:07 am
Post new topic  Reply to topic  [ 49 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: Your car's mileage
PostPosted: Wed Sep 08, 2010 6:25 pm
1992 dodge colt bought from original owner at 61k now has 68k miles having ecu/spark problems.
PostPosted: Wed Sep 08, 2010 6:31 pm
not enough road time :D
1989 Dodge Colt E [4g63T]
2005 Saab 92X awd-turbo :)
2003 WW EVO8 FlexFuel
PostPosted: Wed Sep 08, 2010 10:53 pm
92 Colt 63t Swap - 68,216 on chassis About 400 on engine
95 Caddy DeVille - 108,649
02 Lancer ES - 168,766
PostPosted: Sun Oct 03, 2010 2:04 am
my 92 had 248k on it before it went bye bye and the 91 i just picked up has 157k on it
91 plym colt 4g 4g15 12v/ 4g37 upgrades 5spd flat black
PostPosted: Thu Oct 07, 2010 10:33 am
180,274 (290109.4 km) on the '92 Summit and the car is falling apart. Transmission failing, suspension clunking, rotors warped, head gasket leak (water into cyl), oil leak, Idle speed not adjusting. Besides that it's a great car.
i wish mine took all the abuse yours could handle although i always was topping out on the way back from turboshawns on my favorite road :supz:
1989 Mirage Turbo (Daily).
'89 DODGE COLT GT TURBO.
1994 DIAMANTE - SOLD
PostPosted: Thu Oct 07, 2010 10:39 am
91 mirage se 1.5 12v (titled as a 92), 86,000 miles, iffy first, bought from original owner (old lady) with stock mitsu booklet with all receipts and even oem tire info
PostPosted: Thu Oct 07, 2010 11:17 am
what parts do you need
PostPosted: Thu Oct 07, 2010 1:40 pm
Owner/Admin
89 mirage turbo -miles-189,690 :oops: and swaping a 2.0 into it to keep the miles going...
PostPosted: Thu Oct 07, 2010 11:26 pm
412000km, or at least somewhere near that, plus or minus 1000km.
spun a bearing autocrossing it, replaced the engine, and it was running great, till i sucked a gallon of water into it :p
PostPosted: Wed Nov 10, 2010 9:23 pm
'89 Plymouth Colt 4g15, 4 speed, bought brand new in April '89 for $5800. Currently has 250,000 miles on it. Transmission started popping out of gear around 160,000 (in '96), replaced with 5-speed junkyard tranny which is still in there. This was the only thing that ever went wrong with it.
However, car has not been driven since '02 and hasn't started now in probably 3 years. Was VERY hard to start at the end in '02. Had to crank SEVERAL times in the morning. Engine would stumble a little more each time before finally catching and running. Rest of the day it was fine, then the same thing the next morning. Thought it was the fuel pump, so I pulled the tank and bought a new pump, but the "holster" for the pump got damaged in the process and was badly corroded anyway, so there it sits. Can't find a replacement "holster" without forking over $500 to the dealer for the "holster"/pump combo (they won't sell them separately). Would LOVE to get it running again, but so much to do, so little time to do it (and still no part anyway)...
PostPosted: Fri Dec 24, 2010 4:31 pm
85k on my sedan
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Fri Dec 24, 2010 6:13 pm
I read awhile back in a mag article when buying a used car look to make sure the digits are aligned evenly mostly the first and second digit if there off a good amount someone turned the clock back. Other things to look at are the pedals if there worn out.
PostPosted: Sun Jan 09, 2011 2:42 am
201k on my 89 hatch and still kickin
PostPosted: Thu Apr 28, 2011 1:51 am
I have a 91 base model colt bought it with 160k is at 161k...
And buying some o-z lancer wheels for it on sunday. geting them coated in rota gold and.
While i was added i want to do the big brake from the elantra. or if somehow can show me were i can grind of the knucle to make the vr4 rotor fit. and then just get the dual piston caliper. and get the custom brakcket to make it align.
Anybody can show me how to do this i will highly appreciate it.. And i also wanna drop it. can i put 1g dsm springs on the colt strut?..
I will get pics of my car since i havent i will buy a camera tomorow.
PostPosted: Thu Jun 09, 2011 10:14 am
92 Colt 200 GT 1.5L 12V A/T
Bought for 320 bucks
190,000kms
