It is currently Fri Oct 31, 2025 6:30 pm
PostPosted: Fri Jul 30, 2010 3:39 pm
Yo!
Sometimes, not always (but more often that not lately it seems), the 4G15 keeps running after I turn the car off, turns around once more and sounds really rough doing so.. It's not a problem, apart from that it dumps a whole load of fuel down the carb and floods it so the car is hard to start when you're on the move.. Where's the problem?
PostPosted: Mon Aug 02, 2010 12:54 pm
the carb, or maybe just a vacuum leak. get some carb cleaner, get the car to temp then spray carb cleaner all around the carb base and linkages, is the engine starts to stall you have an air leak, if no stall, somat on the carb, which would req. alonger explaination!
Users browsing this forum: No registered users and 26 guests
