It is currently Tue Jun 04, 2024 5:34 pm
PostPosted: Mon Jul 05, 2010 5:51 pm
I take it I can not fix broken ones in my driveway. The whole assembly must go to a shop?
Thanks,
George
PostPosted: Mon Jul 05, 2010 6:36 pm
Or you can buy a 12 ton press for $100 and do it yourself!
PostPosted: Mon Jul 05, 2010 6:46 pm
Out of pure necessity and wasting alot time/energy you could try to use a vice or a big hammer. At the risk of breaking more parts it might be better to let a pro do it.
PostPosted: Mon Jul 05, 2010 8:40 pm
If the stud will clear behind the rotor, then yes a BFH will knock them out everytime.
I do this everytime we mash the threads on one at work or when I have the luxury of one that was mashed and left for the next guy.
If the stud will not clear, then yes you will have to remove the rotor/hub assembly for pressing.
I can't remember if these captives have to be fully disassembled for stud removal or not.
PostPosted: Mon Jul 05, 2010 9:06 pm
Yeah they need to be pressed
PostPosted: Mon Jul 05, 2010 10:07 pm
I would just spend the money on a pair of expo knuckles. They are a direct swap and it gets rid of the captive rotor setup.
You might be able to fix it with a slide hammer to separate the hubs while its still on the car but I can assure you it will be a PITA.
PostPosted: Wed Jul 07, 2010 7:23 pm
I took the knuckle to the friendly muffler shop. $15.00 out the door!
I will have to look into the Expo knuckles.
