It is currently Thu Oct 30, 2025 12:24 am
PostPosted: Tue Jan 19, 2010 12:19 am
bought this car for $300. found timing belt off by 2 teeth. cleaned tank and replaced pump. it started up after fighting me and i set the timing and it ran ok. i was test driving it and it blew out the exhaust and now it acts like it is flooding. have to hold it to the floor to get it to start. than it will start but it wont idle. you have to crank the idle screw up. i noticed that the engine light has never come on. even when you turn on the key. it is my first mitsubishi. i am a ford tech but am lost on this little car.
also how can i run codes? could i have an ecu going out?
thanks guys
faster than a speeding ticket
1991 colt 1.5 12v
1985 ford ltd wagon 302
2005 f250 6.0l tow rig
1965 falcon 4.6l dohc swap in progress
PostPosted: Tue Jan 19, 2010 11:40 am
I'm going to guess and say you have at least one bent valve. What do you mean by it blew out the exhaust?
PostPosted: Tue Jan 19, 2010 4:18 pm
Time for a compression test. If that checks out ok, I'd start checking sensors starting with the coolant temp sensor.
PostPosted: Tue Jan 19, 2010 4:37 pm
it was running perfect before it started leaking exhaust at the down pipe.
what is the resistance on the sensor? where is the sensor located? is there 2 coolant sensors? (for ecu and for gauge)
what about no engine light?
1991 colt 1.5 12v
PostPosted: Tue Jan 19, 2010 4:50 pm
The sensor with two prongs. Take your ecu out and check for cap leakage and a slightly fishy smell.
PostPosted: Tue Jan 19, 2010 7:41 pm
No engine light...I would believe a circuit has shot in your ecu. Take apart and look for burnt spots or leakage from the capacitors, just like they said.
Good stuff - trucks bring it!
PostPosted: Wed Jan 20, 2010 4:33 pm
thanks guys ill cheak. were is the ecu located. im to lazy to walk up the hill and look.
1991 colt 1.5 12v
PostPosted: Wed Jan 20, 2010 6:14 pm
Passenger footwell, to the right of the hvac blower motor.
PostPosted: Wed Jan 20, 2010 10:43 pm
just looked at it and found slight leak on 2 of the 3 capacitors :( . is a small leak still bad?
1991 colt 1.5 12v
PostPosted: Thu Jan 21, 2010 1:50 pm
Any leak is bad, period. The capacitor isn't functioning like it should, and the acid eats away at the surrounding circuit. Sometimes they can clean and fix them, but your best bet is to buy another ecu. On the bright side, you found out what was ailing your car.
PostPosted: Thu Jan 21, 2010 3:44 pm
If the car still runs I'm betting you can save it. Send it to Dan.
http://www.4g61t.org/forum/viewtopic.php?f=4&t=28271
PostPosted: Fri Jan 22, 2010 5:10 am
Pmed him. would chiping it benifit me at all with it all stock?
1991 colt 1.5 12v
PostPosted: Fri Jan 22, 2010 1:07 pm
Chipping is meant for eprom ecus, usually a 4g63t ecu which then allows differently tuned chips to be installed (or a emulator like ostrich or dsmlink for constant tuning). While some 4g15 ecus are eprom, there would be no point in doing it for a 4g15.
PostPosted: Mon Mar 01, 2010 2:17 am
had caps replaced and still no start.
does anyone have specs on engine sensors? "resistance readings"
1991 colt 1.5 12v
PostPosted: Mon Mar 01, 2010 3:50 pm
http://lilevo.com/mirage/
