It is currently Fri Oct 24, 2025 5:59 pm
PostPosted: Sat Dec 05, 2009 12:06 pm
I had a succesfull conversion/upgrade on my 4G15 8V 4 speed tranny to 5 speed tranny.
Is anyone here try this without issue after conversion?
My problem is my speedometer needles rattles at 60KPH and it seems that my car can't accelerate more even pressing the gas pedal.
is this a problem or issue on incompatibility of engine and tranny? thanks in advance..
My Feedback?
Asked
Bowdown
MattGSR
Coltsfan
Moulin13
Wrx110487
PostPosted: Thu Dec 10, 2009 10:25 am
Its a direct swap. The needle movement is not due to the swap-but due to an issue int he speedo cable system (worn drive gear, worn cable, cluster input needs greese....ect.
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Thu Dec 10, 2009 8:37 pm
may RPM can't react also it fixed on 1.8K? ok i'll check the speedo cable..thnaks
My Feedback?
Asked
Bowdown
MattGSR
Coltsfan
Moulin13
Wrx110487
PostPosted: Fri Dec 11, 2009 2:47 pm
RPM (gauge) has 100% nothing to do with the trans, unless I dont understand what your saying?
Current
08 535ix 420awhp
PostPosted: Wed Dec 23, 2009 9:56 pm
im having an issue after a 4/5 speed swap. Installed the trans and still don't have the 5th gear. wondering if anything in the linkage needs to be changed? or something moved in the shift assy? Or.. i have considered that the trans may just be another 4speed. how do they differ visually? cant seem to find that info..its a 91 dodge colt with the 8v...thanks
PostPosted: Thu Dec 24, 2009 4:53 pm
Most of the cars that I've seen at the yard had a hydraulic clutch setup if they were 5 speeds, the 3rd gens anyway. If its still a cable clutch which I'm guessing it is since you mention nothing about swapping in the hydro pedal more than likely its just another 4 speed.
I have heard of hydro 4 speeds and cable 5 speeds but I've never seen either stock on a 3g (89-92). Then again we're talking about Mitsubishi so anything is possible.
PostPosted: Fri Dec 25, 2009 11:58 am
it was a hydraulic clutch arm. i had to knock out those dowels and swap in my cable arm. besides that it was identical. i was told it was out of a mirage...
PostPosted: Wed Dec 30, 2009 10:20 am
I think you installed another 4 speed tranny.....if the tranny is still on the car try to look for the shiftknob it has only 1,2,3,4 and R..for the tranny itself i don't have idea..
My Feedback?
Asked
Bowdown
MattGSR
Coltsfan
Moulin13
Wrx110487
PostPosted: Thu Jan 07, 2010 1:04 am
Dosent the 5 speed tranny have like a cover over the fifth gear housing in the tranny?
If so couldnt you tell that way?
PostPosted: Thu Jan 07, 2010 4:22 pm
With the car off, clutch pushed in, if you cant put it in 5th gear you have a 4 speed trans. Make sure you got the speedo cable seated well into its socket on the trans.
Users browsing this forum: No registered users and 38 guests
