It is currently Wed Oct 22, 2025 9:38 am
Post new topic  Reply to topic  [ 25 posts ]  Go to page Previous 1 2
PostPosted: Sun Sep 27, 2009 8:41 pm
I'm pretty sure the single wire is for the sender to the gauge and the 2 wire is the sensor you need to be worried about.
PostPosted: Sun Sep 27, 2009 10:07 pm
That is correct. And yes mine was bad enough to set off a CEL and gave me a code. I didn't mess with the maf, I replaced what the ecu told me was messed up and that fixed it.
PostPosted: Sun Sep 27, 2009 10:31 pm
They don't always set off a CEL either. Telltale sign (besides being hard to start) is that it's dumping gas into the motor and you can smell it in the exhaust. The two prong is the one you want, they're about $18+shipping on rockauto or $35 at autozone.
PostPosted: Wed Sep 30, 2009 5:38 pm
Just hooked up the 4G37 ECU and the car runs alot better than it did before. Not to mention that it actually starts, and quickly at that. It also no longer has a very lumpy idle that usually caused the car to die when not revving.
Tomorrow, the MAF and injectors. And then the TB later when I have the time to dremel the plenum.
PostPosted: Wed Sep 30, 2009 7:20 pm
Got a new coolant temp sensor. Starts now like it should. However, it's got a peculiar miss. Likely needs a cap/rotor/plugs/wires now. Oh, to only have a friggen carb.
PostPosted: Thu Oct 01, 2009 8:36 am
Back to square one. It started this morning (30 deg temps). Ran for all of 10 secs, idled down and died. Won't start now. I didn't have time to check codes, but it would appear my "fix" with the coolant sensor was merely random luck for it to work last night.
PostPosted: Thu Oct 01, 2009 11:58 am
Does the tank have to be pulled to get to the fuel pump?
PostPosted: Thu Oct 01, 2009 3:39 pm
Yes. It's 4 nuts that hold it on though I doubt it's your fuel pump. Can you keep it alive by hitting the gas?
PostPosted: Thu Oct 01, 2009 7:52 pm
Yes/no. Sometimes. Sometimes not.
I've convinced myself it's not the pump tonight or fuel system. I tried the car again, ran/started after I unplugged the MAF. Plug it back in, it's missing and won't hardly idle. Prior to unplugging the MAF, no codes.
Correct me if I'm wrong, but wouldn't that mean it's the MAF? If not, what else could it be?
I guess this weekend, I'm going again, to try a handful of ECU's and MAF's to see if I can get this licked. I'm just suprised that a MAF I put on the car, ran/started another CSM I have fine, but didn't make a difference on this car.
PostPosted: Mon Oct 05, 2009 7:48 pm
Didn't mean to horn in on the OP's thread, but given I'm exhibiting similiar conditions, I figure all could learn from it.
OK, I've now tried 3 ECU's in the car. The origional, and two others. The second two came out of two different cars and ran perfect. The ECU's all three exhibit the same condition in the problem car. Upon plugging them in and the MAF, the car won't start and idles like it's running rich after I get it started with the MAF unplugged and unplug it.
I've done the same swaps with the MAF. Although, I'm going to try them again. Same result, MAF unplugged it runs OK, plugged in, runs bad. I measured 2 of the MAF air temp sensors and they checked out.
Coolant temp sensor plugged in or not, produces no noticable change. Only checked it when the engine was already hot.
No CEL or thrown codes at any time until I pull the MAF plug and then, of course, a code(s) for that.
I'm going to start ohming sensors on the throttlebody and MAF.
