It is currently Wed Oct 22, 2025 4:34 am
 Post subject: Adjusting idle on 4G15?
PostPosted: Wed Jun 24, 2009 4:38 am
Yo. I've got a 3G with a 4G15, carb'd auto-choke shit. The idle is too low, how do I go about adjusting it? Do you tighten the wire on the throttle body, or are there other ways to do it?
Thanks 8)
PostPosted: Wed Jun 24, 2009 3:55 pm
Like most carbs out there, there should be an idle set screw. Start at the linkage and follow it to the actuator, somewhere by the bumpstop that the actuator stops on should be a screw to tighten or loosen that will change your idle.
PostPosted: Thu Jun 25, 2009 12:57 pm
its at the back right just about where the bottom fuel line goes past on this pic
