It is currently Mon Oct 27, 2025 12:01 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 26 posts ]  Go to page Previous 1 2
 Post subject: Re: DSM parts FS
PostPosted: Thu Jan 01, 2009 12:22 pm
PM'ed on the flywheel
PostPosted: Sat Jan 03, 2009 11:59 pm
Sorry, I just realized I never went down and looked for you. I will check for you tomorrow.
Bump.
PostPosted: Mon Jan 05, 2009 2:29 pm
I checked the flywheel, and it looks like it has a small crack in it.
Bump for edited prices!
PostPosted: Mon Jan 05, 2009 10:34 pm
pm sent for tranny
PostPosted: Wed Jan 07, 2009 12:52 pm
Tranny sold and changed some prices.
PostPosted: Sat Jan 10, 2009 6:59 pm
Bump! Need these things moved out.
PostPosted: Thu Feb 12, 2009 10:33 am
-17" black racing pro n1 rims with really decent yokohama avs es100's (have ~ 1200 miles on them). One of them has a nail in them, which could easily be removed and patched from the inside. Holds air well. One of the rims has a decent curb rash. Other than that, they are a really light rim set with really decent tires. -600
-Apexi 60mm boost gauge psi- 45
-starter- 30
-2g pistons w/ rods in good shape- 40
-oem 6 bolt flywheel, has small crack- 15
Autometer larger series blower gauge 0-60 psi sport comp- 30
Autometer larger series oil pressure gauge sport comp- 30
Ross Pistons 7.8-1 85mm mounted and ran for a cycle -200
2g coil pack
1g coil pack mounted on a JNZ plate
7 bolt stock clutch (perfect for someone looking to go back to stock)
2g used water pump
Apexi 60mm boost gauge in bar, no glass face to it but works great
2 falken ziex tires 215-45-17 (decent tread, one has nail in it that holds air but can easily be patched)
Garret oil drain line
Dejon leak stop kit
97 Talon Front Bumper (small crack, easily repairable and very sought after bumper!)- 95
2 piston brakes from 2g- 60
18 inch black rims with polished lips. curb rash in a few spots and need new tires
PostPosted: Mon Feb 16, 2009 11:38 am
Bump. Leak stop kit sold.
PostPosted: Mon Feb 16, 2009 9:05 pm
These are the 17's.
PostPosted: Sun Feb 22, 2009 7:49 pm
Bump for lowered prices.
PostPosted: Sat Mar 07, 2009 11:55 am
Bump for some pics.
