I have been looking into getting some SuperPro Bushings for my '89 GT. After doing some "l33t web searching", I was finally able to figure out why I can't find the 3g Mirage in SuperPro's catalog. This is because its listed as a Mitsubishi Lancer CA, CB Sedan 9/88-9/92. After figuring that out and cross referencing some of the numbers from Evol-Art, I came across some bushings Jason didn't list for sale (or rather, he just listed one option of it). The bushing that I am referring to is:
Front Control Arm Lower-Rear Inner Bushing SPF1714K "Standard"
That is what is listed on his website. Well, there are apparently two other options for this bushing, both with different offsets. The part numbers are as follows:
Front Control Arm Lower-Rear Inner Bushing SPF2025K "Single Offest"
Front Control Arm Lower-Rear Inner Bushing SPF2026K "Double Offset"
Now, my question is, what does this offest do? Does it just help with toe or something? I can't really see it doing anything else.
If you want to look for them yourself, or if you don't have a GT you can visit these two sites:
http://www.globalpartssource.com/pdf/SU ... -04%20.pdf (scroll down to Mitsu Lancer CA, CB 9/88-9/92)
http://www.fulcrumsuspensions.com.au/fulcrumCat/ (enter your car)
SPF1714K pic:
http://www.fulcrumsuspensions.com.au/fu ... hp?id=1021
SPF2025K pic:
http://www.fulcrumsuspensions.com.au/fu ... hp?id=2760
SPF2026K pic:
http://www.fulcrumsuspensions.com.au/fu ... hp?id=2761
