so how do u take off the dash? will the speedo come off easy to? i've got two bulbs out on it.
You dont need to take off the whole dash to take off the cluster, but if you wanted to take off the whole dash removing the cluster is required.
There are four screws under the steering column that hold the piece with the wiper/light control knobs on it. Take these off and pull this piece forward to reveal two other screws on top. These hold on the black cover that goes around the cluster.
Remove those to screws and take this black cover off.
The cluster itself is held on by another four screws, two below in front, and two on top behind. This will allow you to get behind the cluster and disconnect the two wire connectors and the speedo cable, (take care of the speedo cable you don't want to damage it). Once those are off the whole cluster comes off.
Let me know if you want pics....
