It is currently Mon Oct 20, 2025 5:50 pm
PostPosted: Thu Sep 27, 2007 6:23 pm
I'm getting the tranny rebuilt. I have a choice for a limited slip differential of Quaife(the gold standard) at $1,200(too much); KTP(?) at $750; or phantom grip at $125(cheap enough, but...)Does anybody have some info.? I tried Goggle and Ask, but the responses were no help.
PostPosted: Thu Sep 27, 2007 10:10 pm
A friend of mine has the phantom grip in his fwd talon. He says it's kinda hit or miss. Sometimes he hooks up, others he just peg legs. You usually get what u pay for. more$=better parts
PostPosted: Fri Sep 28, 2007 7:02 am
And the answer is: Kormex Transmission Parts, a Canadian company (why does that make me feel better?). Their lsd is actually made by Quaife.
On a related note, for those who are NOT intellectually challenged, there is a great article on Mitsu. AWD systems at: www.stealth316.com/2-awd2.htm It is rather long and detailed. NOT a quick read. But the overview is quick and basically informative.
PostPosted: Tue Oct 02, 2007 1:49 am
Is the KTP an LSD or a Torsen? LSD's are fine for the rear diff but they load up the steering too much to be practical in the front diff IMO.
PostPosted: Tue Oct 02, 2007 2:10 pm
"weld it" as long as you have power steering. With good struts and power steering the car will go straight as a arrow. I drove mine everyday without any issues. And the price is right.
Check out this old vid of my car and look how I am not holding onto the steering wheel for dear life like I used to with it being open.
http://videos.streetfire.net/video/6d18 ... fc1b2f.htm
If you watch the end of the video just before the subaru goes boom you can see PTTcolt's car doing the funky sideways dance that open diff and no power steering can do.
89 Colt GT, T4 T61, 2.0L, .
PostPosted: Tue Oct 02, 2007 5:26 pm
My Colt turbo has a SBR(slow boy racing) lsd(phantom grip copy) that is very good quality(actually made in Toronto), and it works very well. The only concern that I see, is when you power out of a corner, instead of the inside wheel going up in smoke, the car now wants to run wide as both wheels are being powered equally. So its easy to get pulled towards the opposite side off the track :-? . I'm not sure how a quaiffe would react in the same situation, but when I need a clutch in the PT GT, I want to install one.
PostPosted: Wed Oct 03, 2007 3:52 am
The only problem with a welded front diff is that if you break a driveshaft in the 1/4 depending on which side breaks will send you either into the wall or across the line into the path of your competitor! :o
PostPosted: Wed Oct 03, 2007 9:10 pm
[quote="gsx"]"weld it" as long as you have power steering. With good struts and power steering the car will go straight as a arrow.
Well, "straight" is fine, but if you do autocross, track time attack, and/or road course, you NEED quick positive turns. (But WOW, I loved the video.)
PostPosted: Thu Oct 04, 2007 1:48 am
The Quaifes are expensive but they are reliable and have next to zero drawbacks when compared to a clutch-pack LSD or a Phantom Grip style device.
I've driven a few FWDs with clutch-pack LSDs and they were all HORRIBLE! Chatter and bucking at low speeds when tight cornering, nasty heavy steering when cornering and accelerating at the same time.
In all the Quaife torsen diffs are definitely worth the $450 premium they attract over the regular LSDs IMO.
PostPosted: Wed Oct 31, 2007 10:04 pm
i have a kaaz in my colt and its great.
gear type diff's are good if you don't mind losing traction whenever one wheel comes off the ground...(ie road racing or auto-xing)
89 Dodge Colt GT
PostPosted: Thu Nov 01, 2007 8:08 pm
That is no longer an issue. The Torsen II diffs have a small preload which prevents that from happening.
Plus if you lift a front wheel you have bigger problems than traction of which more power to the wheels will not help you!
