It is currently Mon Oct 27, 2025 11:15 pm
Post new topic  Reply to topic  [ 58 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Thu Aug 23, 2007 1:44 am
sweet, i think im gonna do this tomorrow night (maybe day) and ill report my findings
PostPosted: Thu Aug 23, 2007 2:31 pm
Brian I sent you a 91-94 coil pack, I'm assuming you need a 90 model with the 4 wire plug? My 94 Elantra that I'm currently swapping uses the 90 style dsm electronics and it has the 4 wire coil connection.
Chris. It's my fault really. I was always under the assumption that 4g61 non turbo wiring was 91-94, probably becuz we got these models (C62A chassis) around that period here from Japan. So when I got the setup from the front-cut in 2003, i said right, i got me a 91-94 setup.
It's only when we had the problems with the 2gMAF and ECU (91-94) last week did we realize that its actually 1990 wiring and electronics.
But ToGarret's suggestion to swap over just the coils sounds like a good plan if I ever need to, so no issues there.
By the way, car's running sweet, breaking in at 9psi and 11 A/F ratio in boost, zero timing adjustment off base.
Full tuning soon, shooting for 280ish at the wheels at 15psi.
96 Lancer Stationwagon - 4G61T swap (rebuilt) (4g67 head, 4g63 intake mani), 390cc's, ported exhaust mani/with 2.5" custom d/pipe, TD04-13g (ported), Greddy Emanage (Gold Edition), VR4 18x12x3 IC with custom piping/hose, SR-20 (Silvia) Recirc BOV, Walbro 255lph pump, custom 2.25" press bent de-cat exhaust, ACT 2100 (4g67 g/box), front EVO II brake/booster upgrade
PostPosted: Thu Aug 23, 2007 3:14 pm
Maybe this post should be sent to the archives, I guess we all learned something new here.
Brian, glad to hear everything is finally running as it should. Now don't sell it! 8)
PostPosted: Thu Aug 23, 2007 6:03 pm
haha..thanks. but already got 2-3 folks interested and currently sourcing a 2004 Toyota Corolla...i think im all done for now :cry:
PostPosted: Fri Aug 24, 2007 2:55 pm
so im confused and i need help. The white wire from the TACH FILLER that is suppose to connect to the dash is connected to the PTR plug right now. Do I disattach it from the PTR plug and wire it into the dash wire? If yes, then how do I know if the PTR is connected to the ECU?
PostPosted: Fri Aug 24, 2007 3:23 pm
I tried following the wire from pin 109 and it keep going and goes thru the firewall before it splits, what am i suppose to do?
91 Galant VR4
PostPosted: Fri Aug 24, 2007 8:33 pm
kay its easy,
you just have to make sure the PTR tach wire (its written like "TCH" on the PTR) is connected to the ecu pin #109
the tach filter needs to be connected to the coils as per lilevos link, then you need to run the tach filters white (i think, its written on it) to the dash.
im sure i've written this like three or more times :)
you can check with a multimeter (continuity test) if pin #109 is connected to the PTR.
PostPosted: Fri Aug 24, 2007 11:28 pm
ok now but now i have the problem that i cant find where the wire from pin 109 goes to a "Y", you said a few inches but i kept searching up through the firewall is where i stopped.
PostPosted: Fri Aug 24, 2007 11:33 pm
maybe in your wiring loom it doesnt split off :?
can you find that dash plug that lilevo talks about, see if you can back probe from that plug to pin #109
if that has continuity then it splits off, if it doesnt, just run the tach filter directly to that dash plug, same as lilevo did.
just make sure pin #109 get its tach signal from the PTR
PostPosted: Fri Aug 24, 2007 11:36 pm
im thinking maybe it doesnt split off, where is the dash plug that needs to connect to the tach filler?
PostPosted: Fri Aug 24, 2007 11:40 pm
i dont know, thats why i said look at lilevo's link :)
PostPosted: Fri Aug 24, 2007 11:44 pm
ok heres the pic
but where the hell is this plug? and do i need to splice in the white wire where that other white wire and electrical tape and red wire is at????
PostPosted: Sat Aug 25, 2007 8:01 am
That plug is still in your car, I didn't cut anything out when I did the swap. I simply made a "connector harness" out of the leftover male and female plugs from the Colt and the Laser so that everything would plug right in. This way very little hardwiring was needed.
I'm assuming Jason just used a red wire to tie into the dash tach wire by the looks of his pic. Find that same white wire that he is referring to on the black Colt connector and you are good to go.
PostPosted: Sat Aug 25, 2007 9:55 pm
Hm, well i still cant find this plug, where should i start looking?
PostPosted: Sat Aug 25, 2007 9:58 pm
Under the carpet, by where the passengers feet would go. Kinda behind the glove compartment but lower.
