1. retaining the nt harness - the nt harness can be completely retained and only needs the addition of some wiring to become the equivalent of the turbo wiring harness.
what you'll need to wire in:
7th wire from mas - the 7th wire from the mas needs to be run back to pin number 6
knock sensor - one wire can be grounded to the engine bay somehow, the other white wire needs to be run back to pin number 9 on the ecu.
wastegate solenoid - one wire here will be grounded, the other returns to the ecu at pin number 105
injector resistance pack - this is the most dificult. i'll let the following pictures describe it rather than trying to explain it in text. if you have any questions just ask.
thanks to don over at aialmatrix for getting mine to run and making this great diagram.
here's a link to my imagestation account where i have the factory ecu prints. the highlighted ones need added, and the model is in the upper corner so you don't get confused.
http://www.imagestation.com/album/?id=4291950155
