It is currently Wed May 22, 2024 11:07 pm
 Post subject: ksport kontrol coilovers
PostPosted: Thu Nov 30, 2006 2:44 pm
i saw these coilovers online and they say they fit the turbo mirage, 36 way dampening and they sound perfect for the autocross setup i want 2 do. lookin for a review on these bad boys or any true coilover system someone has used so far
PostPosted: Thu Nov 30, 2006 4:28 pm
I have heard very good things about the quality of Ksports in the 3/S world. I didnt know they made them for Mirages but I would like to find out.
PostPosted: Thu Nov 30, 2006 7:27 pm
4g61t Delinquent
where did you see it at?
I own a CSM.
PostPosted: Thu Nov 30, 2006 10:17 pm
http://www.ksportusa.com/products/intks ... tions.html
Looks like only 4G and 5G. No 3G application listed.
PostPosted: Fri Dec 01, 2006 8:50 am
Eclipse
(AWD) 89-94 CMT051-KP $1150
9/504
7/392 Incl. Front Pillow Ball Mount & Rear Top Mount
^^^^ That will fit a 3G, just gotta swap the Mirage's rear lower strut bushings into the new coilovers.
My buddy has a set on his S14 240SX. They handle great but they creak. This is apparently a common issue with them (he's researched the hell out of the problem).
1989 Mirage Turbo w/4G63T
1991 Mazda MX-5 (UK spec)
2018 Hyundai I30N
PostPosted: Mon Dec 04, 2006 6:57 pm
Are the upper strut mounts the same for a 4g or 5g Mirage as a 3g? Cause if they are couldn't you just get the AWD 1g DSM kit, and ask for the newer Mirage hats so that it'll all bolt right up?
PostPosted: Tue Dec 05, 2006 4:50 am
How does the quality compare to TEINs?
PostPosted: Tue Dec 05, 2006 4:29 pm
As far as I've been told these things are just re-badged Apex'i coils. Not sure if this is true? Still awaiting answer about hats though :wink: .
PostPosted: Wed Dec 06, 2006 2:21 am
Doubt it, they are made by a Korean company if I'm not mistaken.
*Edit*
Here's a thread on a DSM board about them. They may in fact be the same manufacturer for both.
Also mentioned in the thread is how stiff/harsh they ride. If they are too stiff in a 3200lb car I probably wouldnt want the same ones in a 2400lb car.
http://www.dsmtalk.com/forums/showthread.php?t=167474
PostPosted: Wed Dec 06, 2006 2:43 am
Ksports are identical to D2's.
PostPosted: Wed Dec 06, 2006 3:17 am
From what I heard Ksports and D2 is the same Korean company. Also they do not last very long.
PostPosted: Thu Aug 30, 2007 6:15 am
A lot of 3S (3000GT and Stealth) owners have been having problems with K-sports. The biggest problem is leaking struts, This has happened to about 1/3 of the 3S owners on 3Si.org that have tried them.
The second problemis that some people's Ksports have come out of adjustment height wise. At least 2 3S owners have has the struts hit the hood and dent it.
The best compliment to the K-sports is they use a spring rate that is better for the street. The Tein and JIC aviailble for a 3S are brutally still track only springs. I had a set of TEIN HA's on my Stealth and I took them off after a month because the ride so stiff the car wasn't fun to drive anymore.
PostPosted: Thu Aug 30, 2007 7:26 am
There are a couple of people with 4g and 5g mirages that have had problems with them also. I have not heard any bad things about D2, But alot about ksport. Kinda odd if they are the same.
PostPosted: Thu Aug 30, 2007 8:47 pm
i cant say how they are on csm, or dsm but i have had k sport coilovers on my mr2 and i do not recommend them to anyone.
Ive blown two coilovers and bent the tension bars and i don't auto x or drive my mr2 agressively. They were mounted correctly if you think it was a bad install.
good price but you do get what you pay for. The warranty is okay dealing with customer service if you have a good shop that distrubutes them. Also there is two spring rate to choose from STIFF or STIFF :P
why buy a coilver with all the works that will break down when you can get a set of entry level coilovers from teins for a couple hundred more
thats my 2 cents
PostPosted: Sat Sep 01, 2007 4:29 pm
k-sport.... RUN AWAY...
i've had to install and reinstall waaaaaaaay too many due to blown shocks, on every model .... pure garbage, get a set if teins.
RUN AWAY!
89 turbocan, 63t, GT30-13 (laaaag monster), tubular manifold by me, maf-Trans, phil-tuned ecu, bla bla bla.... you get the drift...
