It is currently Sun Oct 26, 2025 7:04 pm
PostPosted: Wed Oct 18, 2006 7:34 am
WTF is a 4A91? :-?
Got rabies?
PostPosted: Wed Oct 18, 2006 4:44 pm
Engine type ? DOHC 16v, MIVEC, ECI multiple
Displacement ? 1499 cc
Bore ? 75.0 mm
Stroke ? 84.8 mm
Compression ratio ? 10.0:1
Power ? 77 kW (105 PS) @ 6000 rpm
Torque ? 141 N?m (103 ft?lbf) @ 4000 rpm
The Mitsubishi 4A9x engine is a range of all-alloy inline four cylinder engines from Mitsubishi Motors, introduced in the 2003 version of their Mitsubishi Colt supermini, and built by DaimlerChrysler-owned MDC Power in Germany.
PostPosted: Fri Oct 20, 2006 6:59 am
WTF is a 4A91? :-?
The engine found in new Colts (1.5 NA, 1.5 turbo is 4G15T ;))
2000. Hyundai Sonata EF 2.0 (Hyundai version of 4G63 and F5M22)
1991. Mitsubishi Lancer C62 1.5 (4G15, F5M21)
PostPosted: Fri Oct 20, 2006 12:58 pm
So guessing from its designation, this is the 4G91 just with an aluminium block? I think it will have the same pinout as the 5G CSMs. Is it SOHC or DOHC? Do you have pics of the engine?
Got rabies?
