The shift linkage is archived I can guarantee that much.
The starter wiring check the posts here in the last two days and you'll find one that shows
http://www.4g61t.com/phpBB2/viewtopic.php?t=13876, this tells you where the starter wiring goes - it should be the same from a 1.5L to a 4g63 type swap; same bolt holes and locations for both applications.
Wiring posts are archived and should be a writeup by LILEVO, and or netninja2001. Need anymore than this and I might be able to point you in the right direction.
