It is currently Mon Jun 17, 2024 5:25 am
PostPosted: Sun May 22, 2005 5:41 pm
i need some help with the wiring in my colt -- the 4g63 is in and its a 200gt , anyone have done this a couple times who is willing too share knowledge with me.
mostly the wiring inside , and the starter harness, and the shift linkage.
pm me
1993 TSI AWD big16g 20psi
13.2 @ 101.7 mph -- sold --
Colt 200gt + 20g + 660cc + 22psi
PostPosted: Sun May 22, 2005 7:24 pm
The shift linkage is archived I can guarantee that much.
The starter wiring check the posts here in the last two days and you'll find one that shows http://www.4g61t.com/phpBB2/viewtopic.php?t=13876, this tells you where the starter wiring goes - it should be the same from a 1.5L to a 4g63 type swap; same bolt holes and locations for both applications.
Wiring posts are archived and should be a writeup by LILEVO, and or netninja2001. Need anymore than this and I might be able to point you in the right direction.
PostPosted: Tue Jul 05, 2005 5:29 pm
ok . car is running , i just need too meet up with someone so i can check out the dash wiring , (someone with a tsi harness in a colt )
i dont have the manuals ,
anyone willing ?
