It is currently Fri Oct 31, 2025 5:30 pm
PostPosted: Wed Nov 09, 2011 12:52 pm
2g maf
2g to 1g maf plug
2g intake pipe
filter adapter to cone filter
new filter
Ready to bolt on and go.
$100 shipped obo
PostPosted: Sat Jan 21, 2012 12:35 am
are those parts for a 1.6 turbo i will take them if there good is the maf good
PostPosted: Sat Jan 21, 2012 8:08 pm
It was installed on a 91 Plymouth Colt with a 1990 4g63t swap. So its connector will plug directly into a 1g harness. I'm not exactly sure if the 4g61 shares the same maf connectors. If they're the same, you're golden! It also has the better maft of the 2g's. (#609) ****And YES! The maf is good.**** It's mine from out of my car. Every bit of it worked perfectly when it was installed. I just upgraded to a larger setup is all.
92 Plymouth Colt (4g63t, fwd) DD.
05 Jeep Grand Cherokee Limited
(Hemi powered grocery getter) WIFES DD.
PostPosted: Thu Mar 08, 2012 1:02 am
Do you still have this?
1991 Plymouth Colt - Project
