| It was installed on a 91 Plymouth Colt with a 1990 4g63t swap. So its connector will plug directly into a 1g harness. I'm not exactly sure if the 4g61 shares the same maf connectors. If they're the same, you're golden! It also has the better maft of the 2g's. (#609)    ****And YES! The maf is good.**** It's mine from out of my car. Every bit of it worked perfectly when it was installed. I just upgraded to a larger setup is all. _________________
 92 Plymouth Colt (4g63t, fwd) DD.
 05 Jeep Grand Cherokee Limited
 (Hemi powered grocery getter) WIFES DD.
