I run 22psi on pump gas, stock injectors, and stock fuel pump with no problems.
Somethings not right there, plus a 14b at 22 psi is really starting to make more hot air then power. Seen many many cars with 255 pumps 550's and more mods, not able to run 20 psi without knocking, your timing very retarded ie negative 5 or? And a stock sidemount heat soaks and any cars knocks above 18psi on pump on a stock sidemount. Have also seen sevral motors that have very lil sign of detionation but have melted pistions. In short I would back that thing down, remember she always feels strongest right before she breacks. Also most stock BOV leack above 20 psi, which begs the question how much boost are you really making to maintain that 22 psi.
To the orginal question sounds like you have a good mod list, would not wreck your motor by depriving it of fuel, best to spend the $100 and get a fuel pump, every cars a lil diffrent on what boost its happy with, invest in a Data-logger and a EGT gauge.
Corey
90 C50 4G63 Swapped-Drag car
92 Eagle Talon Tsi AWD
96 Mitsu Eclipse GS-T
www.ongreenperformance.com
"Just like in the old days-More Horse Power means more crap to pick up-lol"
