Just grab a 1.6L compressor or one from a 89-92 Galant. All of the other parts are the same as far as I know. Did your car come with AC? I'm assuming its a 1.5L car?
I can't use the dsm compressor??
Maybe with some fab work on the lines but no, the csm lines won't bolt up. I believe the 1.5L compressor is the same but uses a different pulley. Natedog has a thread somewhere on here explaining how he swapped the pulley over. I do know for a fact that the 89-92 galant compressor is the same as the one that comes on the 89 1.6L turbo cars.
Later model Galant 1992 I believe has the tensioner you need to re-install AC on the 1.6L to 2.0L swap; if yours has gone missing or was not there when you bought the C53a 4g61t swapped with a 4g63.
If the car was a C53a that is factory AC equipped and you install a 2.0L, swap over all the AC parts and they will bolt on. Do not try and use the 2.0L brackets for the compressor.
Compressors being the same between the Galant VR4/NA from 89-92 and CSM 1.5/1.6L with the only difference being pulleys is gold right now. You can source used AC compressors on the
www.galantvr4.org site quite frequently, here as well, and rockauto.com, just to name a few places of opportunity.
