It is currently Wed Oct 29, 2025 8:28 am
 Post subject: 4g63t csm with ac??
PostPosted: Tue Sep 27, 2011 9:42 am
Has anyone put back ac in a 4g63t swaped 3g csm?? And if so what parts do you need or is it custom.. Im new to the csm and want to build a 4g63 swap mirage or summit and have ac/ps/heat/etc.. It will be fwd btw
 Post subject: Re: 4g63t csm with ac??
PostPosted: Tue Sep 27, 2011 10:08 am
Just grab a 1.6L compressor or one from a 89-92 Galant. All of the other parts are the same as far as I know. Did your car come with AC? I'm assuming its a 1.5L car?
PostPosted: Tue Sep 27, 2011 10:19 am
If you need the system let me know, just took it out this weekend and it is in pristine condish.
PostPosted: Tue Sep 27, 2011 10:26 am
I dont have a csm i have a dsm. Im moving and bebating on buying a 3g csm as a daily.. I always wanted one.. Id want to have ac in the car since it is florida im moving too
PostPosted: Tue Sep 27, 2011 10:37 am
I can't use the dsm compressor??
PostPosted: Tue Sep 27, 2011 11:54 am
Mine has A/C. I don't recall having to do anything special. I just left it in the car and swapped the engine.
PostPosted: Tue Sep 27, 2011 11:59 am
Maybe with some fab work on the lines but no, the csm lines won't bolt up. I believe the 1.5L compressor is the same but uses a different pulley. Natedog has a thread somewhere on here explaining how he swapped the pulley over. I do know for a fact that the 89-92 galant compressor is the same as the one that comes on the 89 1.6L turbo cars.
PostPosted: Tue Sep 27, 2011 12:02 pm
So i need to use the 1.5 one.
PostPosted: Tue Sep 27, 2011 2:11 pm
The 1.5 and 1.6 compressor is the same part, just swap the pulley. It's like 6 or 8 bolts and it slides right off.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Tue Sep 27, 2011 9:38 pm
Later model Galant 1992 I believe has the tensioner you need to re-install AC on the 1.6L to 2.0L swap; if yours has gone missing or was not there when you bought the C53a 4g61t swapped with a 4g63.
If the car was a C53a that is factory AC equipped and you install a 2.0L, swap over all the AC parts and they will bolt on. Do not try and use the 2.0L brackets for the compressor.
Compressors being the same between the Galant VR4/NA from 89-92 and CSM 1.5/1.6L with the only difference being pulleys is gold right now. You can source used AC compressors on the www.galantvr4.org site quite frequently, here as well, and rockauto.com, just to name a few places of opportunity.
PostPosted: Wed Sep 28, 2011 12:16 am
Thanks for the helpfull info
