My car is losing anti-freeze, every time i check it i have to add about .5 to 1 litre. Compression test shows #1 @135, #2 @115, #3 @125, #4 @125. Hydrocarbon test showed no hydrcarbons in the antifreeze. We put some dye in it, when we put a UV light on the car where ever it is leaking should glow, the only thing glowing was the hose from the overflow jug to the ground.The engine oil does not move at all and it changes color normally. New thermostat, new 12 PSI rad cap, lower rad hose, in-line heater(no block heater). The turbo only puts out 10.2 PSI in all gears at any speed. Do the turbos have antifreeze going through them, could it be going out the turbo into the exhaust system, if so that might explain why my turbo only puts out 10.2 PSI.
