It is currently Mon Oct 27, 2025 2:19 am
PostPosted: Tue Aug 21, 2007 2:47 pm
So I go to start up my whoooopti and it cranks, starts for 2 seconds and dies. If I keep cranking and give just abit of gas and hold both I can kinda keep it alive. but at like 500rpm and after a few seconds it dies.
I do have a CEL... I can't remember how to check the codes on the CSM (been into hondas for too long).
Another thing... can't open my hood, if I unbolt the latch can I open it?
PostPosted: Tue Aug 21, 2007 2:56 pm
Also, I'm not sure if it's the boost or fuel pressure solenoid clicking off..
PostPosted: Tue Aug 21, 2007 4:05 pm
Does it sound like it's coming from under the dash?... near the radio? If so, it's your MPI relay and you most likely have bad caps in your ECU.
PostPosted: Tue Aug 21, 2007 4:20 pm
I used an LED and it's on constant, codes state it's the ECU.
Also it's not the MPI cause I managed to open the hood and it's one of the solenoids either boost solenoid or fuel pressure solenoid....
fruit and banana
PostPosted: Tue Aug 21, 2007 6:22 pm
Turned out to be the ECU.... I swapped in a 1G ecu to runs the 1G upgrades... I cracked open my stock ecu to see the caps... BRAP BRAP EPROM!!!!
PostPosted: Tue Aug 21, 2007 6:45 pm
lol. want to sell your BAD stock ecu. I mean, it's bad and all. I'll take it off your hands for you.
