It is currently Mon Oct 27, 2025 2:31 am
 Post subject: Can't crank it over
PostPosted: Wed Apr 27, 2005 6:45 pm
I just did my lifters and t-belt. After letting the tensioner do its thing for 30min I tried to manually crank it over with 17mm wrench and it's giving me a tough time. I have done it that way before several times and it never gave me such a hard time. I decided not to put all my weight into just incase one of my valves are out of whack and are hitting the piston.
If I try to go counterclockwise it will move freely....could I have just gotten weak and can't crank it over the compression stroke?
SOMEONE REASSURE MY BABY IS OK!!! :oops:
PostPosted: Wed Apr 27, 2005 6:48 pm
U probably have a pump up lifter(air)
Need to remove the lifter and manually bleed it.
PostPosted: Wed Apr 27, 2005 7:37 pm
If I can spin over a 468 cube engine with a cheap ratchet, you should be able to crank that little 4 popper over using your fingers.
PostPosted: Wed Apr 27, 2005 7:45 pm
Thats what I'm saying, I have to check my lifters again.
PostPosted: Wed Apr 27, 2005 7:52 pm
You could try taking out your pushrods (closing all the valves) and then try spinning it over, then you'll know if it's the valves.
PostPosted: Wed Apr 27, 2005 8:34 pm
Um...These engines dont have pushrods...hence the lifters...
PostPosted: Wed Apr 27, 2005 8:50 pm
I think he meant the rocker arms.
PostPosted: Wed Apr 27, 2005 9:18 pm
pull out the spark plugs if you haven't already.......
89 turbocan, 63t, GT30-13 (laaaag monster), tubular manifold by me, maf-Trans, phil-tuned ecu, bla bla bla.... you get the drift...
PostPosted: Wed Apr 27, 2005 9:34 pm
^^He understood. :P :D
PostPosted: Wed Apr 27, 2005 9:35 pm
V8 talk doesn't belong in here!!! :finga: :lol:
PostPosted: Wed Apr 27, 2005 9:40 pm
Mech and his silly v8's. :butthead:
