It is currently Mon Oct 27, 2025 7:00 am
PostPosted: Wed Apr 27, 2005 7:44 pm
does anyone have pics of the trigger wheel and VR sensor hooked up to thier DSM? I'm trying to megasquirt'n'spark my gvr-4 but cant find solid info on how to mount everything.
PostPosted: Wed Apr 27, 2005 8:04 pm
Ive worked on G54B's a time or two, so heres my take:
Why not run the cam angle sensor off your cam??? The DSM CAS just needs to rotate in phase with the cam, and spin at 1/2 the crank RPM. Use a 2.6L caravan camshaft which extends through the end of the valvecover (originally drove the trans-mounted water pump on the caravan) Those vans are all over in the junkyards...I think they wouldve been made in about 1983-85 era. The vans actually had the cool "Mitsu" valvecovers too, so if you find one, grab that too.
Perhaps you could use something like a lovejoy joint or grind a slot in the caravan cam to couple the two together. Make a custom bracket to mount the CAS, and figure out what orientation it needs to be in to make the engine start.
Is that low-buck enough for you???? ;)
The whole basis of EFI swapping is making the computer 'think' the engine is stock.
91 Colt GL "dandelion demon"
PostPosted: Wed Apr 27, 2005 8:14 pm
EAsier said than done. It is possible, I know it, to run the signal from the stock CAS but no one has decoded it yet it seems. Everyone just doest the EDIS or whatever it's called and I cant find any pictures of it on a DSM.
I either need to buy another eprom ecu, since mine too a dump on me, or try and go standalone. If I went with megasquirt I would actually make money after selling my current fuel setup and buying squirt'n'spark.... I just gotta make spark work and I'm golden.
Please, someone point me to instructions on how to make spark work on a DSM.
PostPosted: Thu Apr 28, 2005 6:09 pm
PMA1123 thanks for the input. I even have the mitsu valve cover on there now. Using the mini van cam is a good idea. i will have to check and see what kind of clearence i have back there and how I could mount it. The only thing is I wanted to do a bit of a cam but maybe I could get the minivan one reground.
My plan was to some how make it mount in the hole where the distrbuter went. I will look in to the cam thing further as that seems like the best plan.
Thanks
89 Mighty Max 2.6. Lookin for side drafts 89 Colt turbo. SOLD
91 Galant GSX, waiting for 2.4
