It is currently Thu Oct 30, 2025 6:14 pm
PostPosted: Tue May 11, 2004 8:44 pm
hi guys..
does anyone know about this. I been told that, this ecu can't be over ride.
Is this true... and... wiring for key engine ignition. does anyone know...
thank you. hope to hear from you guys soon...
PostPosted: Wed May 12, 2004 12:52 pm
So what are you trying to do?
The later Proton 4G15 have AFAIK a different ECU than the Mitsus.
Got rabies?
PostPosted: Thu May 13, 2004 2:23 am
actually I'm going to put SAFC. but then my friend said, this ecu cant be overide. Is this true? furhermore, if I want to to change the ecu, I have to mody the TD, intake manifold... and few other tning...is it? correct me if I'm wrong... I'm new in this arena....
PostPosted: Thu May 13, 2004 11:57 am
Ah! The 4G and up 4G1x Mitsus as well as their Proton counterparts use a MAP rather than a MAF. I dunno if the SAFC will work w/ a MAP, but isn't it switchable?
Got rabies?
