It is currently Mon Nov 03, 2025 7:08 am
PostPosted: Fri May 21, 2004 7:19 pm
need to know so i can borrow a buddies scanner
As you slide down the Banister of life,
may the splinters never point the wrong way. :)
PostPosted: Fri May 21, 2004 7:26 pm
its is called aldl.Search the VFAQ's for tips to make your own scan tool. It can be made for like 2-3 bux
http://www.dsm.org/archives/1998/01/199 ... xt/13.html
look here it tells you how to make it
94 Mirage Project underway...
PostPosted: Fri May 21, 2004 11:11 pm
It's OBD-I.
Each manufacturer had their own proprietary OBD-I data protocol. There is no universal scanner like there is with OBD-II. I assume you already know this, but I'd hate to see an unpleasant surprise. If your buddy has something similar to a Snap-On scanner with the Asian cartridge, you should be OK.
Or, you could follow the lead if 91_LaserRS.
Witty Signature Goes Here!
