It is currently Mon Nov 03, 2025 12:25 am
 Post subject: ecu ?
PostPosted: Fri May 14, 2004 9:50 pm
Ihave a 91 plymouyh colt .I just swap in 94 e 4g37 tb maf injectors and ecu then i found a post that get that stuff from a 90 or 91 is there a differance, runs great . have part throttle preignition ill take some timing out and try that. Is this ecu more timing agressive . what would happen with 4g15 ecu and these 4g37 parts
91 colt gl 4g37/5m22 from 94 T/E/L mustang 5.0
PostPosted: Fri May 14, 2004 10:35 pm
ummm, isn't the 94 a completely different generation? also i'm not sure if some wires got switched around on our cars, but on the t/e/l mitsu switched a few wires around on the ecu. hope someone can expand upon this...
PostPosted: Fri May 14, 2004 11:49 pm
I'm running 4g15 ecu and i run a little leanat idle causing a little surging and miss at idle.
Honda Motor Sports=HOMOS
HOMO :lol: :P :wink:
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Sat May 15, 2004 3:31 pm
Yes pull some base timing and your fine I had the exact same issue at paart throttle it was really bad at about 80-85 MPH pulled the base timing and it was fine
PostPosted: Thu May 20, 2004 2:51 pm
CSM O.G.
Homos On Nitrous Driving Aggressively, thats one I heard in a parking-lot down here, ROFL
and I cant wait to get my 1.8 ecu in the mail!!
