It is currently Mon Oct 27, 2025 5:23 am
PostPosted: Thu Apr 22, 2004 8:34 pm
I have a 4g15 1990 colt hb, and well...... one battery is GONE, it's swelled, and leaks acid like a freshly cut throat.... I put another battery on, as my other one couldn't turn over the motor, when checking how much volts were passing back to the battery, I got readings of 18 volts!!!!, this is bad, and I need to know would be wrong?
Alternator?
Power regulator of some sort?
HELP!
Thanks. -Andrew
PostPosted: Thu Apr 22, 2004 8:39 pm
Have your alternator checked
 Post subject: replaced alternator
PostPosted: Fri Apr 23, 2004 12:52 am
replaced the alternator with one from my parts car, hehehe she's alive and running well again... :D old alternator had play in the shaft/pulley etc.
Thanks. -Andrew
PostPosted: Fri Apr 23, 2004 2:50 pm
18 Volts -> bad voltage regulator.
Got rabies?
PostPosted: Fri Apr 23, 2004 3:44 pm
I just got over that same problem, ha ha. I had a dead engine. I replaced the battery then a few months passed and she went dead again then I got pissed and broke something on my dash and took it over to my uncles and he told me my alternator wasn't charging my battery so I replaced that and then it went dead again so it was off to my uncles and, whats this?! my alternator went dead.... again (never buy you parts from Schucks, there name fits them) anywho, I replaced it again and the only problem i was having is the alternaton keeps wanting to come loose but that was fixed yesterday. Man that was a pain in the a$$.
I have never bought a car for more then 500 bucks.
First Car. '75 Toyota Celica GTS- $300
2nd- '89 Dodge Colt GL- $300
3rd- '90 Mitsubishi Mirage- $400
4th- '90 Toyota Pick Up- $500
5th- '93 Mitsubishi Eclipse- $100
PostPosted: Sat Apr 24, 2004 3:24 pm
voltage regulator is built into the alternator, what fun that would be.... just replace the alternator.... well.. I had an extra one so thats easy to say..
