It is currently Sun Oct 26, 2025 10:45 pm
 Post subject: clicking injectors
PostPosted: Wed Apr 14, 2004 8:00 pm
they are kind of loud
is this normal for this car
RX-7 Fanatic
PostPosted: Wed Apr 14, 2004 9:04 pm
does you car rev like it normally should, we had that problem on my friends talon and it wouldnt rev. it ended up that the timming was way off.
http://www.turbo4g63.com
PostPosted: Wed Apr 14, 2004 9:42 pm
runs fine
i think they are dirty, its not getting over 32mpg
RX-7 Fanatic
PostPosted: Thu Apr 15, 2004 1:24 pm
How old is the fuel filter? If it's old replace it first. Try a can of injector cleaner. If it doesn't help... maybe it normal then. :-?
I know of some Toyotas, Mazdas and a few other CSMs that always make that sound. It seems to be normal and not a bad thing, as they all run pretty good.
Your mileage doesn't look that bad. Did you alread check the oxygen sensor?
Got rabies?
PostPosted: Thu Apr 15, 2004 2:27 pm
the o2 sensor seems fine
it does need a new filter
ill get one and some more MMO
RX-7 Fanatic
PostPosted: Thu Apr 15, 2004 3:03 pm
What's MMO? :oops:
Got rabies?
PostPosted: Thu Apr 15, 2004 3:32 pm
What's MMO? :oops:
Marvel Mystery Oil,rotary engines secret weapon :D
its a good gas and oil additive, good cleaner
RX-7 Fanatic
PostPosted: Fri Apr 16, 2004 6:28 am
:o secret mystery stuff always does it, dude! 8)
Got rabies?
PostPosted: Fri Apr 16, 2004 9:17 pm
32 miles per gallon isnt bad???? thats weird, im getting about 31 in the city and 44 on the highway[/quote]
PostPosted: Sat Apr 17, 2004 7:46 am
H3ll, I wish I had 32 MPG back then. I had 22-25 MPG.
Got rabies?
PostPosted: Sat Apr 17, 2004 11:37 am
[/quote]
im getting 32 on mostly highway
RX-7 Fanatic
PostPosted: Tue Apr 20, 2004 2:56 am
Ditto that, I get about 30-32mpg city and ~40mpg highway plus I have a lead foot when driving the 4G15. However I made several changes that improved it 10-15% over when I first got it - ported(cleaned-up)/matched head, deburred and polished combustion chambers, CAI and Finer Filter, cleaned and balanced fuel injectors.
PostPosted: Tue Apr 20, 2004 4:36 am
BANNED FOR FRAUD
You sure it's the injectors that are making the noise and not the lifters or valves?
Jason Veraldi
Scammer
PostPosted: Tue Apr 20, 2004 5:55 am
ye my valves r making nose only somtimes i dont know y its only somtimes. i think i should get them tuned up. its not making my car go any slower so it all cool
LAnCeR GsR 4G61
69.7KW @ 6000rpm
Genie Header
K&N Airfilter
60mm throttle body
PostPosted: Tue Apr 20, 2004 4:05 pm
My injectors click like a miniture tap dancing team but they work fine.
