Notice that you need mods slow_93_1.5,
Check this link for interchange stuff.....
http://www.4g61t.com/forum/viewtopic.php?t=7480
Your easiest options if you don't want a direct drop in motor swap and the time associated/tools needed to pull this off, are to open up the restrictive exhaust system at the muffler and open the intake. TB is a good next step. If you do things one at a time, then you won't get too lost if something goes wrong. If you need more info, PM me or do a good search, there is TONS of info in the back posts on stuff to do to these cars, even though you have the newer body style your engine stuff and mechanicals are still in the same ballpark.
