It is currently Sun Oct 26, 2025 5:43 pm
PostPosted: Wed Apr 07, 2004 12:58 pm
I think my sensor is toast, can i use my 1G TSI sensor? also its never been replaced so how am i going to get it off? i stand behind the car and i cant stand the smell. I'm not sure whats with the car, i dont think its my cat or muffler, i got some nastiness coming out of it...also, the car bogs could it be the sensor or ecu on its way south? i just replaced the injectors and put some treatment through....can any one give me some feedback.
It wont pass emission and i dont know what to do about it.
Thanks
-Dom
PostPosted: Wed Apr 07, 2004 2:20 pm
No the Sensor on a 1G is a 4 wrire the 4g15 is a 2 wire....
PostPosted: Thu Apr 08, 2004 8:40 am
Berserko, why shouldn't he be able to use it? He just has to wire the extra heater wires to GND and to the purge control solenoid (sp?).
Got rabies?
PostPosted: Thu Apr 08, 2004 9:38 am
Well I should rephrase it... its not plug and play..
PostPosted: Thu Apr 08, 2004 12:19 pm
OK that's true.
Got rabies?
PostPosted: Thu Apr 08, 2004 7:06 pm
...purge control solenoid (sp?).
Your spelling is correct. :)
Witty Signature Goes Here!
PostPosted: Sat Apr 10, 2004 8:37 am
Thanks Kyle! :D
Got rabies?
PostPosted: Mon Apr 19, 2004 6:47 am
ive got an o2 sensor prob aswell...smells like crap!
ive been told that after 100,000 kms (yes im in australia) which is about 60,000 miles i think they become officially shagged...
the o2 controls the air/fuel under 2000rpm while the ecu controls it above that. they are cheap to buy...
anyone else in aus??
PostPosted: Mon Apr 19, 2004 7:33 am
BANNED FOR FRAUD
[quote="Fro-Daddy"]ive got an o2 sensor prob aswell...smells like crap!
anyone else in aus??[/quote
If it actually smells like crap then that's your cat going out. And I don't know about in the land of Oz, but the o2 sensor keeps track through the whole power band. It's how the ECU knows what's up.
Jason Veraldi
Scammer
PostPosted: Mon Apr 19, 2004 8:46 am
It's not the cat, it was fitted with a new cat not too many miles ago (remember wrotek?)
PostPosted: Mon Apr 19, 2004 9:12 pm
if you run your car with no o2 sensor the car idles as rich as ya mum...this happens all the way until 2000rpm...where the ecu takes over.
if i reset my ecu, and get a new o2, will that stop my car from running rich?
PostPosted: Wed Apr 21, 2004 1:31 pm
The ECU controls A/F mixture in closed-loop which is sustained from idle to a certain rev limit (4000...5000 revs), and if the coolant is warm, and the throttle isn't moved w/ more then a certain speed or amount.
To learn more about open- and closed-loop modes, read the DSM ECU primer somewhere on the net.
You could try resetting your ECU, but I doubt it will gain anything. A new O2 sensor AND resetting the ECU will probably solve the whole problem.
Got rabies?
