It is currently Sat Oct 25, 2025 6:53 pm
 Post subject: Mitsubishi Axle lengths
PostPosted: Sun Dec 21, 2003 9:23 am
This table shows the lengths of axles that mitsubishis use may make life easier at the wreck if you know what fits where.
Application Inner Joint Outer Joint Length in. (mm)
Eclipse
2WD
1.8L
Left ................ TJ .......... BJ ......... 27.9 (709)
Right ............... TJ .......... BJ ......... 14.5 (368)
2.0L (A/T Turbo)
Left ................ TJ .......... BJ ......... 27.6 (702)
2.0L (All Others)
Left ................ TJ .......... BJ ......... 27.8 (706)
Right ............... TJ .......... BJ ......... 14.4 (366)
4WD (A/T)
Left ................. TJ .......... BJ ......... 14.4 (366)
Right ................ TJ .......... BJ ......... 14.6 (371)
4WD (M/T)
Left ................. TJ .......... BJ ......... 14.5 (368)
Right ................ TJ .......... BJ ......... 14.5 (368)
Galant
2WD
SOHC
Left ................ TJ .......... RJ ......... 27.9 (709)
Right ............... TJ .......... RJ ......... 14.5 (368)
DOHC
4WD
A/T
Left ................ TJ .......... BJ ......... 14.4 (366)
Right ............... TJ .......... BJ ......... 14.6 (371)
M/T
Left ................ TJ .......... BJ ......... 14.5 (368)
Mirage
1.5L
Left ................. TJ ....... BJ or RJ ...... 27.4 (696)
Right ................ TJ ....... BJ or RJ ...... 14.5 (368)
1.6L
A/T
Left ............... TJ .......... BJ ......... 27.2 (691)
Right .............. TJ .......... BJ ......... 14.3 (363)
M/T
Right ............. DOJ .......... BJ ......... 14.1 (358)
3000GT
SOHC (A/T)
Left ................. TJ .......... BJ ......... 16.5 (419)
Right ................ TJ .......... BJ ......... 15.5 (394)
SOHC (M/T)
Right ................ TJ .......... BJ ......... 16.0 (407)
DOHC (A/T)
Left ................. TJ .......... BJ ......... 16.4 (417)
DOHC (M/T)
Right ................ TJ .......... BJ ......... 15.9 (405)
4WD
Right ................ TJ .......... BJ ......... 15.4 (391)
(1) - Right indicates passenger's side, and left indicates driver's
side.
(2) - Type of CV joint used are identified by letters as follows:
BJ - Birfield Joint, DOJ - Double Offset Joint, RJ - Rzeppa
Joint, and TJ - Tripod Joint.
