It is currently Tue Oct 28, 2025 12:02 am
PostPosted: Tue Oct 21, 2003 8:42 am
Here's a list of things that need to be changed right away. These aren't optional. Ignoring these items will definitely leave you stranded one day.
The timing belt - Unless you have a record of it being changed recently, change it now.
The ECU Capacitors - Again, unless you know they've been changed, you really need to change them. The cost of changing them is like 1/100 of buying a replacement ecu.
Things that are a good idea to replace. Items marked with a * can be replaced with upgraded parts.
- Spark Plugs
- Spark Plug Wires *
- Fuel Filter
- Air Filter *
- BISS O-ring
- tranny fluid
- engine oil
- radiator fluid
- tie rod ends
- ball joints
- wheel bearings
- all rubber parts (hoses, bushings)
PostPosted: Tue Oct 21, 2003 8:48 am
Guys add to this list. I want to stick this into the archives.
PostPosted: Tue Oct 21, 2003 9:16 am
Nobody Important
Don't forget to change the oil in both the engine and tranny. Coolant is a good idea too.
As with any car, check the steering/suspension too.
  • Jack up one of the front wheels so it is off the ground. (Insert obvious safety disclaimer here)
    Sit on the side of the car facing it and grab the top and bottom of the wheel and try to pull the top towards you while pushing the bottom away (and vice versa). If it wiggles, you need new ball joints.
    Now grab the front and back side of the tire and try again. If it wiggles back and forth you need new tie rod ends. Now the exception with this one is if you are really trying hard to move it you will be flexing the tire on the other side of the car so you will get a little bit of wiggle. You are mainly looking for "slop" in the steering.
    Repeat on the other side.
One more thing, if it is made of rubber INSPECT IT. Coolant lines, Intake lines, CV Joint boots etc.
It doesn't hurt to replace things to get it all at a known state (well, it can hurt the wallet and sometimes the knuckles :))
-paul
PostPosted: Tue Oct 21, 2003 11:12 am
don't forget safety items,
brakes,
brake lines for cracks,
change brake fluid if it is black/dark grey, should be almost clear,
headlights/tailights/brake lights
PostPosted: Tue Oct 21, 2003 2:42 pm
Since I'm getting my engine from a junkyard, I'll be replacing:
- all the gaskets in the engine
- while im in there, checking all the valves and pistons for damage
- compression test the cylinders
- check out the turbo for rubbing/damage/play
- replace accesory belt while replacing timing belt
PostPosted: Tue Oct 21, 2003 10:50 pm
i think a leakdown test is more accurate than a compression test. lets you know if either an exhaust valve, intake valve, or rings are bad.
dont forget the balance shaft belt when you do your timing belt. or just install a eliminator kit
The resurrection begins.
90' Plymouth Laser RS Turbo (donor)
90' Dodge Colt (2.3L 4g63T swap)
PostPosted: Wed Oct 22, 2003 7:42 am
don't forget safety items...
..also get Fire Extinguisher. It wont cost that much to keep one in your GT.
Sonny F. Walukow
1999 Toyota RAV4
1990 Honda Accord
1989 Colt GT (Sold)
