It is currently Mon Oct 27, 2025 9:07 pm
 Post subject: Rattlesssss
PostPosted: Wed Sep 24, 2003 8:06 pm
please tell me what you do with the rattle...
PostPosted: Thu Sep 25, 2003 12:31 am
BANNED FOR FRAUD
Tighten down as much crap as you can. If that doesn't work, use some double-sided foam tape to insulate the part and keep it from rattling.
Jason Veraldi
Scammer
PostPosted: Thu Sep 25, 2003 10:45 am
I agree with that. I striped my entire interior and layed down roofing tar on the floor, doors, roof, trunk. Bass got sooo much better then I went to the local home depot and picked up 3/4" underlay (the stuff you put under carpeting so you cant hear whats going on in the basement or whats happening upstars) so I put all that down then put my interior back together tight. No more rattles, ALOT less road noise and bass perfection!! I had 2 pioneer 12's (pieces of shit) runnin on a 800 watt orion and ppl could hear me comming 2 km away! No bullsh*t. I went to fill up with gas one time and the owner came out to ask me to "please turn it down" cause apparently I was rattling stuff inside the store :twisted:
This one is taken from the trunk ^. I didnt take the dash off at that point
How many Civics does it take to beat a Mitsubishi?... We dont know, its never been done. F*ck the Civics.... This is a Mitsubishi Nation. Represet
'89 Dodge Colt 100e with many toys of the 200gt
PostPosted: Thu Sep 25, 2003 7:42 pm
I have a problem with the plast trim fasteners in the hatch area and the screws on the rear speaker mounts. About once a month i have to dig around and collect half a dozen or so and replace/tighten them. Lock-tite here i come!
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Wed Oct 13, 2004 3:42 am
Urethane adhesive(windsheild glue) works wonders,and urethane foam for real problem panels(ringing Q panels). 8)
New toy in the works....
World finals,here i come!!
http://www.termpro.com/asp/competitorst ... 1&Season=0
Team Canada at work
http://www.termpro.com/dbdrag/photos/E6 ... 81P25C.jpg
PostPosted: Mon Nov 22, 2004 4:15 am
you can buy any cheap aluminum tape at a hardware store and apply it to your car. also, you can use rubberised undercoating for cars or etc. another thing you can do is get cheaper matting from ebay and just get at least 100SQ FT
PostPosted: Thu Dec 23, 2004 11:08 am
I say put foam tape on your license plate. Tighten everthing down. I also have used the expand a foam in certain places to help keep things tight. Like the braces on car trunks. Be careful when you use it though because a little goes a long way. But most important find out where you are rattling from.
