It is currently Sun Oct 26, 2025 7:36 pm
 Post subject: T belt question???
PostPosted: Mon Aug 18, 2003 3:27 pm
Are the 4g61t motors interfierence? I stripped teeth off of my t belt at the crank part and pulled right over the other night. It broke when i was babying it at 50 mph in 5th gear. I know when you break a tbelt on a 4g63 your f*cked due to the fact that the pistons will hit the valves. Is this true on the 4g61, a motor with a lesser stroke?
89 Colt GT, 4G63T, 60-1 @ 30 psi, NX wet 75 shot...
97 Jeep Wrangler
PostPosted: Mon Aug 18, 2003 3:57 pm
Yep, it's an intereference engine. I purchased my mirage with a busted head from the timing belt breaking.
PostPosted: Mon Aug 18, 2003 8:57 pm
Since the 4G61 has a shorter stroke the block itself is also about 6mm shorter to bring the head closer to the piston or else you would have a gaping cavity in there. IOW: you bent valves...
PostPosted: Tue Aug 19, 2003 3:06 am
open the sucker up and find out. its the only way of knowing if you did or not. my friend with a 4g63 did it and no internal damage at all!!!! i couldnt believe it!!! but i dont like ya chances.
PostPosted: Tue Aug 19, 2003 3:43 am
If you break the T-belt while your just idling then you have a slight chance of getting lucky. A compression test will tell you whether anything isn't sealing (from the bent valves) without removing the head.
PostPosted: Tue Aug 19, 2003 3:33 pm
All the valves are straight, and there was no damage. Let me rephrase what happend. The belt didnt break, it stripped the teeth off of a section of the belt at the crank at 2800 rpm, then i pushed the clutch in and pulled over. All the new crap goes on tomorrow and she'll be terrorizing 5.0's in no time flat :wink:
97 Jeep Wrangler
