It is currently Sun Oct 26, 2025 10:06 pm
 Post subject: HYUNDAI SONATA MANIFOLD?
PostPosted: Sun Aug 17, 2003 11:39 pm
I just went to a local yard and found a intake manifold off a Hyundai Sonata.....Will this fit my 63t in place of my cyclone intake? If so what else can be used?.....I also aquiered two IC's, one off a SAAB (Wich is a high volume side mount IC) and the other off a Ford Probe (Wich was a front mount style simalar to a starions'. Any suggestions on wich to use?
89'SILVER MIRAGE 4G63T (bad headgasket)
PostPosted: Mon Aug 18, 2003 12:16 am
yes the intake manifold will fit as for the IC i would use the probe rather
that the sabb one
Member 209
89 Colt GT RIP
92 Mirage 4dr
91 Celica
http://members.sounddomain.com/gage1
http://community.webshots.com/user/miragegt
PostPosted: Mon Aug 18, 2003 1:03 am
Nobody can accurately tell you whether the Sonata manifold will fit unless you can tell us what year Sonata it is from. ie: only some Sonatas use the DOHC 4G63B.
PostPosted: Mon Aug 18, 2003 3:14 pm
XLR8: is right more product specific information is needed. Some came with a SOHC 4g64 and it will NOT fit. If it uses a DOHC 4g63 it should fit without issue....
 Post subject: SONATA MANI......
PostPosted: Mon Aug 18, 2003 11:50 pm
I looked for an engine code and coulnd't find one. I know it's an early model (probably off a 90-91). The engine was a DOHC and looked exactly like 63t. The only difference was that the throttlebody comes with an attatched plumbing (not detatchable like ours).
PostPosted: Tue Aug 19, 2003 1:14 am
Sounds like the right model then. From memory the engines are coded comething like G4CP (4G63) and G4CN(4G61-Elantra.)
PostPosted: Tue Aug 19, 2003 11:58 am
and G4CS for a 2.4L Sonata
