It is currently Mon Oct 27, 2025 12:25 am
PostPosted: Fri Aug 15, 2003 6:34 pm
Anyone got a picture of the exhaust manifold from a Starion turbo?
My engine's cracked (4g32) and I was going to get a 4g63 to replace it - they guy wants over the odds for it (just the bare block and head only, nothing else with it) but I reckon I can talk him down and get him to trhow in the exhaust manifold.
IF it has a bolt bolt pattern that will fit a Garrett T3 then all I have left to buy is the Engine Management System.
PostPosted: Tue Aug 19, 2003 3:57 am
Can anyone help with this? I'm considering going 400 miles to get a complete 4G32 (1.6 turbo) engine with all the running gear - but I could spend the same on an immaculate 4g63 (2.0l 8V turbo) and the exhaust manifold locally. Then i just need other bits to get the car running properly again.
I need to make my decision which I'm going for before Friday - because at the moment, transport to the other end of the country is a bit of a problem!
Also related: What inlet manifolds can I put on the Starion engine? Does the galant MPi match up? Will a cyclone inlet manifold match up? If I'm going for the 2 litre, I'm going for an MPi manifold too!
